CMS ~ K&N Filter and Typhoon Intake Sale!
K&N’s replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
Drop-In High Flow Filter: ONLY $39.99
Fits: #33-2345
06-09 LEXUS IS350 3.5L
06-09 LEXUS IS250 2.5L
07-09 LEXUS GS350 3.5L
06-07 LEXUS GS430 4.3L
Fits: #33-2381
07-09 LS460 (2 filters required)
Fits: #33-2326
07-09 GS350
08-09 LS600H (2 filters required)
Fits: #33-2220
01-05 GS430
01-09 SC430
06 GS300
07-09 GS450H
Fits: #33-2137
98-00 GS400
00-06 LS430
Fits: #33-2260
02-03 ES300
04-06 ES330
03-06 RX330
07-09 RX350
Fits: #33-2170 - (Price for these is a bit more as it is a much larger filter)
98-05 GS300
00-05 IS300
*90-00 LS400
Built for performance and show, the Typhoon Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine's RPM range.
Estimated Horsepower Gain: 11.27 HP @ 5800 RPM
Typhoon Air Intake System $249.00
Fits:
05-07 IS250
06-08 IS350
01-05 IS300
2007 GS350 - Estimated Horsepower Gain: 18.11 HP @ 5751 RPM
The Generation II FIPK is K&N's ultimate performance product, designed to increase power by as much as 10%. Most FIPK's are street legal in all 50 US states and come with a Million Mile Limited Warranty. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction as they smooth and straighten air flow. This allows your vehicle's engine to inhale a larger amount of air than the OEM air filter assembly. More air means more usable power and acceleration throughout the engine's RPM range. The filters on these kits are washable and reusable.
Generation II FIPK ~ $299
Estimated Horsepower Gain: 9.34 HP @ 5977 RPM
Fits:
98-00 GS400
01-05 IS300
JUST ADDED LEXUS IS-F K&N AIR INTAKE SYSTEM!
For even more power from your IS-F, K&N has designed a new air intake system (69-8703TS) in powder coated silver for the 2008 Lexus IS F with 5.0 liter V8 engine. K&N dynamometer tests show a 28.15 horsepower gain at 5900 RPM with use of this K&N air intake system. K&N tests multiple vehicles for each air intake kit it makes to ensure a consistent horsepower and torque gain.
The 69-8703TS has a mount for the factory mass air sensor. Simply remove it from the stock air box and install it into the K&N free flowing mandrel bent aluminum intake tube, securing it with the provided hardware. It is designed to reduce restriction and provide the benefits of a washable and reusable lifetime replacement K&N air filter (RT-4590). This K&N cone shaped air filter has a titanium top for added strength and light weight.
The stock air box restricts air flow to the engine. K&N performance air intake systems provide an increase in power while providing excellent filtration. The K&N air filter is protected by a heat shield assembly which fits into the engine compartment and allows the K&N air filter to receive a consistent flow of fresh air.
This air intake systems are designed to be installed in 90 minutes or less and are backed by the famous K&N Million Mile Limited Warranty.
Link to Dyno chart - http://www.kandn.com/dynocharts/69-8703_dyno.pdf
MSRP - $499
*PM us for special intro pricing on this Awesome new product!
