- How to Use Voice Commands
Step by step instructions for do-it-yourself repairs
Browse all: Interior
BUILD THE IS-F FAQ - Need your help!!!
https://www.clublexus.com/forums/is-...-f-recall.html
Link: https://www.clublexus.com/forums/is-...rake-pads.html
https://www.clublexus.com/forums/is-...-interior.html
Also, I can't seem to find a DIY for low beams on the IS, it'd be nice to put that up as well.
Good stuff so far guys!
Refreshing the call for FAQ nominations for the IS-F. PLEASE POST A LINK TO THE THREAD ALONG WITH THE NOMINATION!
I have some, created by our new IS-F moderatorCaymandive
1) Modification / Independent dyno resutls thread https://www.clublexus.com/forums/is-...o-bs-here.html
2) DIY Front Brake Pad https://www.clublexus.com/forums/is-...rake-pads.html
Please help us out by nominating some additional helpful threads!
Issues and Concerns
Water pump leaking- https://www.clublexus.com/forums/is-...p-leaking.html
Worn valve guides- https://www.clublexus.com/forums/is-...fs-engine.html
Wheel pitting- https://www.clublexus.com/forums/is-...on-08-isf.html
Inside tire wear- https://www.clublexus.com/forums/is-...alignment.html
How To's
Front Rotor replacement- https://www.clublexus.com/forums/is-...ke-rotors.html
Headlight adjustment after drop- https://www.clublexus.com/forums/is-...-too-high.html
Rear Sway bar- https://www.clublexus.com/forums/is-...way-bar-2.html
Checking the level or draining overfilled AT fluid-https://www.clublexus.com/forums/is-...ion-issue.html
DIY Oil change- https://www.clublexus.com/forums/is-...il-change.html
Tires
Increasing tire size- https://www.clublexus.com/forums/is-...and-downs.html
Winter wheels and tires- https://www.clublexus.com/forums/is-...nd-wheels.html
Lighting
3000k fog lights- https://www.clublexus.com/forums/is-...d-in-fogs.html
Last edited by caymandive; Nov 28, 2011 at 12:10 PM. Reason: Added Rotor replacement DIY
RPM & Speedo - Blue Needle partial LED failuers
Nav Display - Touch Screen failure
Font & Rear Brake Squeak - LSB's issued for 2008-2011
I will add more topics as I remember.. (I will dig up the threads later)
~ Joe Z
