Whining noise near Torque Converter
Old Feb 22, 2009 | 08:33 AM
LS400_96's Avatar
LS400_96
Default Whining noise near Torque Converter
Hello,
I have a '96 LS400 with 170,000 miles and am getting this whining noise from the bell housing near the torque converter.
The noise is the loudest when I start the car when it is cold. Once it starts to warm up, the noise decreases. But when the engine is reved up to about 2000 rpm in park, the noise comes back.
When driving, the whining could be heard. The transmission shifts fine without any issue. But occasionally when coming to a complete stop, a clunk is heard and the rpm drops to about 150 rpm causing the car to shake a little.
I went underneath the car and am hearing noise near the torque converter. It sounds like a seized bearing. Is there a bearing near the torque converter? Is this what happens when the torque converter is bad? I did a transmission fluid flush at 155,000 miles with the factory fluid and the transmission is shifting fine so I don't think the transmission is the problem. I would like to hear your opinions. Thanks for your time.
Old Feb 22, 2009 | 01:58 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Sounds like your transmission mount is gone. Replacing the mount will reduce noise, vibrations and the whining you describe.
I cannot tell you more without a closer inspection.
Old Feb 22, 2009 | 02:44 PM
Rocan's Avatar
Rocan
i agree with grand ls... transmission mount.
or if its not that id say the torque converter is shot... which shouldnt really be an issue unless if this thing was drived hard etc...
if it is, the best replacement out there is the one from lextreme
Old Feb 22, 2009 | 11:54 PM
LS400_96's Avatar
LS400_96
I changed the tranny mount 6 months ago so I doubt that is the problem.
Could a worn torque converter make this kind of noise? Anyone have any experience.
Old Feb 23, 2009 | 12:10 AM
LS400_96's Avatar
LS400_96
If it is just the torque converter, could I just change this or do I have to rebuild the transmission.
Old Feb 23, 2009 | 12:21 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
you can change just the TC, although it's rare to see them just go.
Old Aug 9, 2009 | 02:39 PM
vaughn37's Avatar
vaughn37
I am getting a whining noise also... when the car is in park....and i press my brake pedal the noise gets louder..or when i turn the lights on......I can also hear the noise good when coming to a stop in sync with transmission down shifting..any idea's?
Old Aug 10, 2009 | 02:08 PM
mista808's Avatar
mista808
Clogged transmission filter.....
Old Aug 10, 2009 | 02:10 PM
vaughn37's Avatar
vaughn37
hi i replaced it with a new one when i flushed the tranny
Old Aug 13, 2009 | 09:40 AM
mista808's Avatar
mista808
I read it in your first post, but its possible it has gotten clogged... ill bet my star wars trading cards, its clogged.... haha
Old Nov 4, 2009 | 10:26 PM
ryan1lx's Avatar
ryan1lx
Default torque converter?
Originally Posted by LS400_96
Hello,
i have the exact same problem with my car.have u found the problem with your tranny yet?
Old Nov 4, 2009 | 11:27 PM
97CE LS400's Avatar
97CE LS400
Rear diff starts to whine when going bad to.
Old Dec 2, 2009 | 03:58 AM
vaughn37's Avatar
vaughn37
my whine was fixed with a new alternator
quaiduhm
Jul 30, 2011 08:57 PM
Abear
GS - 1st Gen (1993-1997)
Apr 26, 2010 09:35 PM
machinegt
Apr 15, 2005 08:40 PM
redgs400
Performance
Jul 10, 2003 10:06 AM
