How to turn off Oil Maintenance Warning and Light
Search is not my friend
That method does not work with my 2007 ES 350. It does not have a reset button and an odo button. It has one button that cycles thru odo, Trip A, Trip B, which zeroes out the trip meters when held down. There is no separate "reset" button.
Anyone else?
Anyone else?
To reset oil maintenance light, follow these steps:
1. Set trip to A by pushing in the stem under the speedometer.
2. Shut off ignition.
3. Press in stem and hold as you push start button twice (do not put foot on brake).
4. After seeing a row of 0000000 from odometer, release stem.
5. Start ignition, it will go through check and light will be out.
Muhammad33 (04-06-24)
Oil Maintenance Light is now off
That worked on my 2007 ES 350. Thank you. Also, some web posts say to set trip to ODO, but it must be set to A or it won't work!
ehryciuk
01-26-09 08:08 AM
