CA Beat Sonic Navigation Bypass BB4618
Information about the Beat-Sonic Navigation and DVD Bypass Modules:
System: 100% Plug and play kit from Beat-Sonic for allowing use of factory features that would be locked out during vehicle movement.
These plug and play module kits allow override of the lock out system equipped in your factory TV or Navigation/DVD system when the vehicle is in motion. Due to the fact that no modification is needed on the factory harness and this is 100% plug and play, it is easily reversible to the original factory specs without showing any signs that this modification was ever made.
This bypass module is equipped with a programmable LED-lit button where the override of the navigation lock out can be switched off automatically in a specified time (2, 3, 5 minutes or constant) after the bypass is engaged.
Once the button is engaged, the module tricks the factory navigation system to thinking that it is at a stop and enables the use of all the controls including the navigation address input, POI, blue-tooth contacts, mp3 music select, etc. When the button is depressed, the vehicle will return to its normal state and will take couple of seconds to refresh the correct vehicle location on the map. This module will also bypass the DVD during vehicle movement for car models with a DVD Player.
There is no 30 second bypass limitation to this unit.
Compatibility:
- All models with or without Mark Levinson. For models without a factory DVD player, the unit is still compatible and will still unlock features that lock out when the vehicle is in motion.
2011-2012 Lexus CT 200h
2010-2012 Lexus ES 350
2010-2011 Lexus GS 460
2010-2011 Lexus GS 350
2010-2011 Lexus GS 450h
2010-2013 Lexus GX 460
2010-2012 Lexus IS F
2010-2012 Lexus IS 350C
2010-2012 Lexus IS 250C
2010-2012 Lexus LS 460
2010-2012 Lexus LS 600h L
2010-2012 Lexus HS 250h
2010-2012 Lexus RX 350
2010-2012 Lexus RX 450h
2010 Lexus SC 430
2010-2011 Toyota Land Cruiser
Compatibility:
2010 Lexus SC 430
vettestr
RX - 4th Gen (2016-2022)
03-06-17 01:35 AM
BeatSonic
Club Lexus Vendor Marketplace
13
04-14-13 06:49 AM
