Swift Springs on an IS350
Hey has anyone ever tried the swift springs? it drops the front my 1" and the back by .8". Its supposed to have a nice ride quality but i havent seen anyone with it so far. Does anyone know of a good place to install springs in the San Gabriel valley?
Hello,
I am interested in the Swift springs because they are the only ones I fund to be linear (very important to me). However I am concerned about the spring rates.
The Stock spring rate on the IS350 are 263 lb/in front and 291 lb/in rear. The rates on the swifts are 258 lb/in front and 291 lb/in rear.
Usually lowering springs have higher than stock rate to make up for the less travel you have.
Are you guys bottoming out or hitting the bump stops?
Did the car come down the advertised 1" f/ .8" r, or did it drop more?
Any problems with them at all?
Thank you.
PS if anyone knows of any other linear springs for the IS350, please let me know. I AM NOT INTERESTED IN COILOVERS
Thank you.
Thank you Javy,
it looks good but it also looks lower than the advertised drop of 1f /0.8r
The spring rate questions I asked earlier I need to have answered if anyone knows anything plz chime in.
I will PM pocky to ask if he bottoms out or has any problems at all.
Are their ant other linear springs out there?
Hello,
Thank you.
Thank you.
Mostly personal preference from LOTS of experience on and off tracks, but linear rate springs (like the stock springs) are just a whole lot more predictable. You can look up the differences on the net but for this type of car its what I prefer.
I called swift and I have seen pics of the ones for the IS, and they are linear.
Given that Swift uses linear rates, it makes you wonder if cars will stay off the bump stops given the approximate 1" drop. Sounds like they are sensible with modest drops for maybe for that reason as well as not messing up geometry/alignment too.
I see, similar to why I prefer a constant ratio for steering, not variable ratio steering systems.
One member had Tein CS coil-overs he traded for H&R springs then got the swifts. He said the swift felt and handled better.
I am going to get them soon and I will update this thread.
Thats what I was thinking too but the front rate being a lil lower than the stock rate made me pause. The members that have had them say that they are great and that they never hit the stops. The only reason they changed them was to go lower.
fyi - With my newly installed Eibach 350's (about 450 miles so far), I've only bottomed out once in front and not harshly. For brisk/legal driving the car feels a bit flatter in the corners.
