I fixed my misfire (check engine light p0300, p0301, p0302)
and borrowed the code reader. Misfire code on #1 and #2.
p0300, p0301, p0302.
Symptoms were a very rough idle, but the car was still driveable.
Pretty sure I had bad coils. Talked to my Mazda Master Tech brother...
he said coils do have a tendency to die out. I went ahead and ordered 3 new
coils since the rears were difficult to get to.
Toyota moved to a new PN 90080-19016 I paid $90 each.
I believe there is a TSB on this issue.
Well I had to dismantle alot to get to the back plugs!
I guess I had a lot of practice with tight spaces on my MR2 Turbo.
The RX300 sure rivaled it in difficult of removing the intake manifold.
1 ground strap, 2 stay brackets, and 2 hard pipe bolts very hidden
on the backside of the manifold. Lots of fun!
I removed all plugs and inspected. Besides being sooty/dirty/slightly oily -- they
were fine. Once I replaced the #1 and #2 coils -- it idled just fine and the
check engine light went away.
Total R&R time for me was around 6 hours. Fun stuff. Good luck to all those
who have to do the same job!
Could you tell me how they marked cylinders? what cylinder is #1, #2...?
maybe someone can attach a picture?
By the way, thanks to Lexmex and Meetya for the help: I had P0171 code. mechanic charged $160 to fix it. in two months CEL was up again with the same code. and I fixed that for free in one minute by cleaning MAF with electronic cleaner. Thanks guys!
One must look at the age of the part that is failing and if there are multiple parts, one should weigh replacing all of them.
For the case above, if 2-3 coil-packs failed, I would have replaced all six. Most probably the others came from the same batch and if 2/6 failed, the others would most likely fail shortly. [pessimistic attitude, but why go through the hassle again and again]
Salim
now it's my turn to share an experience. and ask another question.
with P0302/P0302 code I switched ignition coils on 2-nd and 4-th cylinders. OBD showed P0302/P0304. I supposed P0302 came with computer memory. I purchased new ignition coil 90080-19016 (original was 90919-02234) at Toyota dealership and install on 4-th cylinder. codes disappeared immediately. I ran the engine for 10 min, then drove 5 miles. everything looks ok now.
the only question to professionals is: with codes OBD had red lid up. now (without codes) it has orange lid up. is that normal? should it be green?
Not sure I have ever heard of that. If you have a CEL on the dash, then there should be an accompanying code. Without any codes, there should be no CEL on the dash.
Only other time you can get no CEL on the dash and have codes is with pending codes that eventually can turn into a non-pending code and cause a light on the dash.
Salim
Last edited by AMN; Mar 4, 2008 at 07:34 PM. Reason: I do not see a picture I attached to the message
For the readiness monitors to be okay, you just have to keep driving, usually an hour or so of straight driving before they reset themselves.
My uncle has a more advanced Actron OBD2 scanner I bought him and it notes these things and I notice it will have an issue if I have just disconnected and reconnected the battery.
