Installing traction control in non-TC SC400 ?
How hard would it be to enable / install (factory) traction control in an SC400 that didn't come with it preinstalled? I wondering if it is just a matter of picking up the additional ECU, and the shift plate with the TC switches. Does anyone have any insight or personal experience on this?
*Plus its just another safety feature for wet roads and gravely roads.
gadgetSC
many reasons, many reasons.
The TC works by both pulling back the throttle when wheel slippage is detected, and also by applying the ABS brakes to the one spinning wheel to bring it's rotation back in line with the rest.
Anyway, installing it in your car would be a hassle. Besides the ECU and console parts that you mentioned, you'd also need the special throttle body with the sub throttle valve, a TC master cylinder, a TRAC accumulator, plus the TRAC pump, the ABS actuator and TRAC brake actuator, and all the associated plumbing and wiring, including the wiring going to the left and right rear wheel speed sensors and throttle position sensor.
The Lexus repair manual devotes dozens of pages just to the traction control system, it's not a simple piece.
-=Photon=-
