Reset 'Oil Maintenance Required' LS460
Old 01-23-08, 07:00 PM
lwilliams
lwilliams's Avatar
Default Reset 'Oil Maintenance Required' LS460
I changed my engine oil and filter at 15K and I don't know how to reset the light. Please help if you know the procedure. It says "Oil Maintenance Required" and has yellow triangle with exclamation mark in middle of it.
Thanks in advance.
Old 01-23-08, 07:54 PM
EGLIDE
EGLIDE's Avatar
I remember reading it somewhere in the owner's manual.
Old 01-23-08, 08:04 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
yup, it's in the manual. could be wrong, but do you reset it in the navigation -> maintenance screen? find it in the manual
Old 01-23-08, 08:37 PM
ccds
ccds's Avatar
I did mine but I had to look it up in the manual.
I don't remember the sequence so I guess you will have to look it up to
Old 01-23-08, 09:06 PM
lwilliams
lwilliams's Avatar
Ok no problem. I didn't know it was in the manual. I hate reading all that. ha..but will get it out tomorrow.
Thanks much.
Old 01-24-08, 12:27 AM
onepointon
onepointon's Avatar
I believe the LS460 has this system. Sadly I havent changed the oil on many of them. Try this:
Make sure the trip odometer is NOT on 'Trip A' or 'Trip B' (ie: just the normal ODO). With the ignition off, press and hold the reset button. Press the 'Start' button twice without pressing the brake, but while holding the reset button. The dash will let you know its reseting, just keep holding the button until it is done.
Old 01-24-08, 12:50 AM
teamplayer
teamplayer's Avatar
^^^That is correct. Make sure the Trip/Odometer is set to "trip A". With ignition off press and hold the reset button. While pressing the reset button, press the start/ignition button twice to turn ignition on. Keep watching the trip/odometer display to flash the lines (-----) until you see it flash the zeros (00000) then it'll read out your "trip A" again. Then you release the reset button.
Old 01-24-08, 08:55 AM
lwilliams
lwilliams's Avatar
Thank you very much..Works great!
Old 01-24-08, 09:30 AM
onepointon
onepointon's Avatar
Thanks for confirming that. I knew I was close. The only reason I wanted to confirm that was because some models are a tad different.
Old 01-24-08, 11:48 AM
teamplayer
teamplayer's Avatar
Yeah. The older ones, you'd leave it on the odometer reading (NOT the trip a). That's the only difference though.
Old 01-24-08, 02:26 PM
Nospinzone
Forum Moderator
Nospinzone's Avatar
That's great to know for future reference. Thanks to Onepointon and Teamplayer. You know, Teamplayer is a real team player!
Old 01-24-08, 03:20 PM
onepointon
onepointon's Avatar
I know the ES350 needs to be on 'Trip A' as well. When I was thinking about it last night, for some reason I had the TPWS initialization stuck in my head. That one is different. I dont see many oil changes so I wasnt 100% sure.
Old 01-24-08, 05:48 PM
lsauto
lsauto's Avatar
BTW, what is the recommended mileage for first oil change on the 460? thx.
Old 01-24-08, 06:25 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
5000 miles, first service
Old 10-19-12, 11:28 AM
franktx1
franktx1's Avatar
Owners manual section 4.3 page 561 (2008 manual) under "After changing the engine oil."
This is in the Do it yourself section 4.3 in the manual.
Quick Reply: Reset 'Oil Maintenance Required' LS460
