Upholstery/Carpet Dying
Old Dec 26, 2007 | 01:54 AM
DasBach's Avatar
DasBach
Default Upholstery/Carpet Dying
Searched and didn't really get any good answers; does anyone know of some good products to dye upholstery? I am needing to dye a headliner black. Preferably the same hue as the carpet/ material in a black interior Sc300. If anyone has some good advice, it would be much appreciated.
Matt.
Old Dec 26, 2007 | 06:09 AM
vipsoarer's Avatar
vipsoarer
search for SEMs dye. Its high quality and goes on very easily. All you need to do is clean the part, let it dry, then spray on the dye. You can dye a whole pannel in about an hour start to finish. VHT is another good company. Both should be very similar in color. I would go with either a flat black or a semi-gloss due to the gloss being overly glossy.
Old Dec 26, 2007 | 04:28 PM
Gunnar's Avatar
Gunnar
I used VHT to paint my steering column and my center console. I cleaned them off with simple green, let them dry, and painted them.
On the steering column especially it really soaked in because it kept the texture of the plastic, and when I screwed a gauge pod onto it the paint didn't chip or peel at all.
Old Dec 26, 2007 | 05:22 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
your search button is broken.
Old Dec 26, 2007 | 09:47 PM
DasBach's Avatar
DasBach
The posts I found pertained to panels and dashboards. I need to dye the carpet upholstery headliner. Also, a lot of the threads don't show up as the network here blocks pretty much anything.
Old Dec 26, 2007 | 09:48 PM
JesLet's Avatar
JesLet
SEM will work on carpet bro.
Old Dec 26, 2007 | 10:31 PM
DasBach's Avatar
DasBach
Thanks man, I'll check out SEM.
Old Dec 27, 2007 | 03:33 PM
thaimonkee's Avatar
thaimonkee
i heard SEM is for plastic/vinyl. Other have used RIT dye for carpets. Hope this helps.
Old Dec 27, 2007 | 03:35 PM
JesLet's Avatar
JesLet
I was thinking about Rit dye.. how did it turn out? Any pictures?
Old Dec 27, 2007 | 03:39 PM
thaimonkee's Avatar
thaimonkee
I havent tryed it yet. I just read it on other forums. A member here dyed his flow carpet with it. He said he had to do it twice since the first time turned out purplish. but after the second coat it looked good.
Old Dec 27, 2007 | 03:49 PM
JesLet's Avatar
JesLet
I believe that's DX3... I remember you have to soak it for several days.
Old Dec 27, 2007 | 06:10 PM
kaotiq's Avatar
kaotiq
Dood. Just pay for the new carpet from a reupholstery shop. All that dye just to save a few bucks?
Old Dec 28, 2007 | 06:38 AM
thaimonkee's Avatar
thaimonkee
how much would carpet at an upholstery shop cost? Plus you would have to cut it out to shape. I think im just making it sound harder than it really is.
Old Dec 28, 2007 | 02:12 PM
kaotiq's Avatar
kaotiq
It can range anywhere from $75-200 including install depending on the shop and how reputable it is. They do it all for you.
I just don't get the members here that want to rip their own interior apart, buy the dye, spend countless hours cleaning, then dying the interior, reassemble, and put it all back together. That's a LOT of work and time. Cost-value analysis will show that you're probably only saving a few bucks here and there. Pay a pro to redo the entire car!! Spend the money if you're going to build a superior vehicle.
"Do it once and do it right."
Old Dec 28, 2007 | 10:05 PM
J_Atreides's Avatar
J_Atreides
I saved up a lot of links of DIY or other misc custom stuff for SC since I've joined the forum. Here's 1 for DIY dye. Could be useful.
https://www.clublexus.com/forums/sho...d.php?t=169045
HF
