Swaybar Bushings-- $12.99 -- Energy Suspension-- Installed and awesome--
Old Jun 11, 2007 | 07:20 PM
  #46
CleanCL's Avatar
CleanCL
all energy suspension bushings are poly
Old Jun 11, 2007 | 07:39 PM
  #47
vwynn's Avatar
vwynn
sounds good.
ok so i was wondering about the price.. how come the black one is a few dollars cheaper then the red? hah
im planning on putting energy suspension bushings for the shocks.. (KYB GR-2) before installing it. wonder whats the size for the bushings.. hmm
Old Jul 22, 2007 | 11:45 AM
  #48
B1TEM3's Avatar
B1TEM3
is this method for sc400 only? would there be swaybar size difference on sc300?
I want to try this on my sc300
Old Jul 22, 2007 | 12:04 PM
  #49
MJHSC400's Avatar
MJHSC400
You can buy poly bar-stock and mill it to whatever size you want-- I was thinking about doing that as a side business actually....
The SC300 should use the same stuff-- pretty sure about that--
I believe black and red are different durometer (hardness) ..........
Old Jul 22, 2007 | 02:28 PM
  #50
B1TEM3's Avatar
B1TEM3
Upgrade in on schedulle (hate noise too, I want to be able to steer my lexus with 1 finger)
Front LCA with Daizen camber kit
Front and rear bushing with Energy
Front steering rack bushing Daizen
Old Nov 6, 2007 | 09:30 PM
  #51
SCoupe's Avatar
SCoupe
CL Folding 25,000
Default Your bushings are probably worse than you think, mine sure were...
I can't resist an under $20 upgrade that may bring meaningful results. From the outside, my bushing looked perfectly good. How that changed when I had them in my hands. They were crumbly and worn on the inside. The rubber was beginning to disintegrate. My sway bars are MKIV Supra TT, and use the 7/8ths diameter Energy bushing 9.5158r on the rear fits it perfectly.
I have a NASA event at Infineon this weekend and I’ll know more about any improvements then. EDIT: WOT wheel hop issue in second and third gear appears to have vanished, major bonus !
Pix worth a thousand words. Here is what the old ones looked like followed by the new install:
Old Nov 7, 2007 | 08:02 PM
  #52
fwynn's Avatar
fwynn
Originally Posted by RedPhoenix
do u really have to cut it like that?
Old Nov 7, 2007 | 08:58 PM
  #53
SCoupe's Avatar
SCoupe
CL Folding 25,000
I think it says earlier in the thread that the front bracket fitment is tight and you have to cut it like that. Should not affect anything to make that cut.
No cut for the rears, straight bolt up, see my pix. Install is on a MKIV TT rear sway on my SC300, don't know if that matters. Takes longer to wash and wax then put on the rears.
Old Nov 7, 2007 | 09:14 PM
  #54
fwynn's Avatar
fwynn
sweet i think this will be our weekend project :]
at first i was like DANG it will slip off and then ur screwed.. but then i looked at it again.. and i was like dang.. how the HELL can it slip off haha yea im slow
Old Nov 8, 2007 | 07:26 AM
  #55
IS_Sunny's Avatar
IS_Sunny
Does anyone know the diameter of the Sway bar on a 94 Sc300?
Is it the same as an Sc4?
Old Nov 8, 2007 | 08:07 AM
  #56
SCoupe's Avatar
SCoupe
CL Folding 25,000
Same...the SC300 and 400 both use these bushings per
Originally Posted by MJHSC400
...For my SC400, the front is the 1 1/8" bushing set, and the rear is the 7/8" bushing set-- universal-- no brainer-- on an aisle at most parts houses--
Fit my setup perfectly.
Old Nov 8, 2007 | 10:26 AM
  #57
ChronoJ1's Avatar
ChronoJ1
I just ordered the bushing from Summit (damn 10 dollar handling charge...what a rip-off). Anyways, i didn't have to buy the grease separately, right? It's included? Also, to the OP... can you show how much of the braket has to be ground and which part?
Old Nov 8, 2007 | 10:55 AM
  #58
SCoupe's Avatar
SCoupe
CL Folding 25,000
These are common in stock items at Kragen, Autozone PepBoys and probably other majors. No grease included, they are dry.
Edit to reply to question below:
Originally Posted by ChronoJ1
As far as grease goes, so you don't need to apply any greese at all? Then what is the greese insert points for?
Yeah, sorry a little confusing...I said none "included"...yes they require grease at the time of install and periodically via a grease gun per instructions.
Old Nov 8, 2007 | 11:13 AM
  #59
ChronoJ1's Avatar
ChronoJ1
Doh! I didn't know they were that readily available.
Old Nov 8, 2007 | 08:15 PM
  #60
RedPhoenix's Avatar
RedPhoenix
Grease port is for easy "refill" after installation.
