NE Buying springs with 12/14k stiffness
Old 01-16-17, 05:06 PM
LexusKnown
LexusKnown's Avatar
Default Buying springs with 12/14k stiffness
Just looking to replace the springs on my Tein Flex Z coils for them to have a stiffer ride besides the dampening adjustment. However, if someone was looking to buy the teins then i would just buy another set of coils.
LexusKnown is offline
Old 01-21-17, 06:35 AM
kwanye
kwanye's Avatar
i have 14k/12k springs from a set of BC coils.
kwanye is offline
Old 01-21-17, 08:01 AM
LexusKnown
LexusKnown's Avatar
Do you know the specs of the spring? Like is it 7" in diameter?
Old 01-22-17, 09:13 AM
kwanye
kwanye's Avatar
no i don't. sorry..
kwanye is offline
Old 01-22-17, 09:28 AM
mindcrime
mindcrime's Avatar
first, do you have a 250, 350 or F? second, is you IS a DD with track or no track duty? based off those questions, then select a spring rate
mindcrime is offline
Old 01-23-17, 09:57 AM
LexusKnown
LexusKnown's Avatar
It is a is250, it is a DD with no track duty. Thank you for those clarifying questions!
Old 01-23-17, 09:58 AM
LexusKnown
LexusKnown's Avatar
Do you have pictures you could send me in a message?
no i don't. sorry..
Old 01-23-17, 12:07 PM
mindcrime
mindcrime's Avatar
call swift springs and ask for there recommendation. i'm not sure on the specs of the Tein shocks so they'll be able to assist you better rather than taking a chance of getting a spring rate that's to harsh or soft for your liking.
Old 01-23-17, 12:48 PM
St4nc3
St4nc3's Avatar
I have to agree with OP. depends on what you're trying to do with your car and how you want it to ride. as for the length of a coil. its measured as follows ID (inner Diameter) come in sizes like 60mm, 62mm, 65mm etc etc. and length are measured in mm as well and they typically come in sizes like 180mm, 200mm, 220mm etc etc. I pretty sure BC coils overs are 62mm ID. and 180mm length which is also 7.1" in length.
St4nc3 is offline
Old 01-24-17, 07:45 AM
LexusKnown
LexusKnown's Avatar
Thanks for all your replies guys! Im going to gonahead and call and see what they tell me. Thank you again if mods want this can be closer or moved to an informational forum incase people are curious about springs upgrades or something.
avinad
01-04-15 10:19 PM
VDMTom
Suspension and Brakes
10-22-14 10:51 PM
stlgrym3
03-17-14 10:52 AM
TuscaniLuv
10-20-11 03:56 PM
RMMGS4
02-03-11 09:41 PM
Quick Reply: NE Buying springs with 12/14k stiffness
