looks like someone had some KW's installed!! GLWS!!
Since these are the revised suspension 2011+ of I am correct, would these be doable on an is 350? I know the the suspension is designed for a heavier car, but just curious.
From what i read they do fit on a IS250/350 and will sit lower than stock and much stiffer. They were revised for better comfort at slower speeds. I read some springs such as Swift springs will not work for them. There may be an update not sure.
and yes 2ndgf. i installed some KW and currently love them.
They should fit. You may need to find stock top hats since the were used on my stock from what i read.
So I can use my old top hats(from '08 is250 ) with the F suspension right?
However, the coilover for isf doesnot fit is250/350. Ive check the KW3 coil, they have diff part#...
