FL FS OEM Battery $40
Old 07-24-11, 01:59 PM
robertrios
robertrios's Avatar
Default FS OEM Battery $40
Switched to a yellow top, this one was still in perfect working order and was replaced by the dealer under warranty in 2009.
Would prefer local since its heavy!
Thanks!
rjrios@mail.usf.edu for a faster reply.
robertrios is offline
Old 07-24-11, 02:01 PM
xspsi6
xspsi6's Avatar
Can you post a pic? I would like to see the group size of the batt and where are you located?
xspsi6 is offline
Old 07-24-11, 05:32 PM
robertrios
robertrios's Avatar
Model # 2880054232
Couldnt find info on it but other members have reported up to 9 years of usage from these. Made in Japan by panasonic i believe.
I looked online and the dealer had a replacement listed for 1k...could that be correct?
Anyhow im in Tampa, Fl
Old 07-24-11, 05:43 PM
xspsi6
xspsi6's Avatar
I can't tell from the side which group size it is but it should be on the label on the top, I just need to make sure it will fit my car before I comit to buying it.
xspsi6 is offline
Old 07-24-11, 05:50 PM
robertrios
robertrios's Avatar
here is the top, i cant find much info on them other members might know more or maybe even the dealer? I can do some more research after im done with my homework
Old 07-24-11, 06:35 PM
xspsi6
xspsi6's Avatar
No worries I will find out for sure in the morning since I have a friend in the lexus parts dept.
xspsi6 is offline
Old 07-24-11, 07:52 PM
kumquatism
kumquatism's Avatar
I think the ISx50s are listed as a group 24 (at least, that's what came up when I searched for a replacement). I measured the battery that I pulled from my car. It's roughly 10.25" wide, 7" long, and 8" tall.
kumquatism is offline
Old 07-24-11, 09:17 PM
robertrios
robertrios's Avatar
if it helps at all the optima i bought to replace this is a 34/78 and was not as tall as this stock battery.
Old 07-27-11, 12:07 PM
robertrios
robertrios's Avatar
bump...someone needs a battery
gs3_4me
Maintenance
03-07-24 08:32 AM
chippy1202
IS F (2008-2014)
28
10-22-15 08:19 PM
FutureGS400
Performance
02-04-05 06:16 PM
CrzyBimmer
RX - 1st Gen (1999-2003)
08-01-03 09:46 PM
tn52
08-29-01 07:59 AM
Quick Reply: FL FS OEM Battery $40
