IL FS: oem hid bowls
Old 10-31-09, 12:22 PM
FinLIFE
FinLIFE's Avatar
Default FS: oem hid bowls
pair of oem hid bowls out of my 01 gs430. I did the ls430 retro and no longer need these. In mint condition with the little levels on them still. Asking $50 for the pair. Lmk if interested. Pics if necessary. I have bulbs also and I can sell those for a little extra.
FinLIFE is offline
Old 12-15-09, 09:27 PM
FinLIFE
FinLIFE's Avatar
ttt..with or without bulbs..lmk.
FinLIFE is offline
Old 12-16-09, 07:48 AM
GS400Jay
GS400Jay's Avatar
Can you email me pictures to me -- gs400jay@gmail.com.
Thanks!
GS400Jay is offline
Old 12-17-09, 11:23 PM
a#'z
a#'z's Avatar
Damn that's a deal, but i don't need it. lol, how much did you buy the retro ls?
a#'z is offline
Old 12-19-09, 11:32 PM
FinLIFE
FinLIFE's Avatar
It actually came out more than most ls retros just because I bought tsx clear lenses..special brackets..etc. I didnt want to go cheap when doing any of it so id say around $400-450 when all was said and done.
FinLIFE is offline
Old 12-20-09, 08:54 PM
AliGS300
AliGS300's Avatar
would these fit in the gs300 stock headlight?
AliGS300 is offline
Old 12-20-09, 09:16 PM
FinLIFE
FinLIFE's Avatar
I am not too sure on that, but im sure someone has done this or can say from experience. Ive never taken apart a non hid gs light to say it will or wont for sure.
FinLIFE is offline
Old 12-22-09, 01:05 PM
URDONE
URDONE's Avatar
Yes, you'll obviously need ballasts to make it work and a wire harness but they do fit.
URDONE is offline
Old 01-02-10, 10:19 PM
Caoboy
Caoboy's Avatar
These need the clips for them to bolt into non hid housings, I don't see them on your set. Do u have them? They are bigger than non hid clips. If u have them I'll take them.
Caoboy is offline
Old 01-02-10, 10:48 PM
tonysgs300
tonysgs300's Avatar
so whats the difference on the HID bowls and the non HID bowls? they look pretty similar?
tonysgs300 is offline
Old 01-02-10, 10:51 PM
Caoboy
Caoboy's Avatar
One is for HID and the other is for Halogen. The design of the reflector is different. The mounting tabs for the clips for the bowl to attach to the housing are bigger on the HID ones, but they both bolt up to the housing fine.
Caoboy is offline
Old 01-03-10, 10:33 AM
FinLIFE
FinLIFE's Avatar
If you are referring to the little plastic inserts where the screw goes into then I don't, I had to use that when I did my retrofit. I have some from is350 and rx330 headlights if those will work for you??
FinLIFE is offline
Old 01-03-10, 03:01 PM
Caoboy
Caoboy's Avatar
You should check and see if they fit...otherwise these can't be used for a proper HID conversion on the nonHID version.
Caoboy is offline
Old 01-03-10, 06:12 PM
FinLIFE
FinLIFE's Avatar
I brought them inside and the clips are a tad bigger, but if trimmed down with a exacto knife no more than 1mm they will fit. I can provide pictures if anyone is interested.
FinLIFE is offline
7i4styleGS
06-08-14 12:52 PM
sw2oboi
12-12-12 01:22 PM
swat1727
03-06-09 08:26 AM
upstateGS4
04-12-06 01:01 AM
lexusondubs
General Classifieds
15
06-11-05 08:42 AM
Quick Reply: IL FS: oem hid bowls
