Review of HKS silencer inserts for Hi-Power exhaust
I finally got the gumption to order them last month, and they took a whole month to get here (cardomain.com). They were also a lot more work to install than I expected since the "coffee cans" are nearly impenatrable by a drill. Those suckers melted several of my good bits with a corded hi speed drill.
Anyways ... it didn't start off good, but I datalogged my torque curve with and without them within about half an hour, and I also did videos from outside the car. To my EXTREME surprise, the difference in sound level isn't at all noticeable from the video, but it is very noticeable from inside the car. It has TOTALLY removed my desire to put the stock exhaust back on. The drone is no more!
http://www.youtube.com/watch?v=Zgz-2BuKM0w
Back to the torque curve... it is nearly the same! It ain't worth a second thought!
The yellow and pink lines are the torque with the silencers and the blue is without.
Bravo for being the guinea pig on this one. Glad it didn't remove any power.
I'll try to remember to take a picture this evening, but honestly, they are very hard to see when they are installed. The only visible difference is really just the allen headed bolt that holds it in. Depending on where you drill the hole, that won't even be very visible. I drilled mine on the bottom so they would just be visible from some angles, and would be easy to take off.
It uses a allen head nut and a bolt to hold the insert in place?
A set of black finished ones might be the most visually appealing.
I would be interested in this "option", especially for long trips where I might actually find the drone objectionable.
Exactly which "insert" do you order. I think there are 5 of them listed.
