How to change the oil on your GX470
First you need to gather the tools needed for the job.
A ratchet with a 10mm, 12mm, a14mm sockets and a flat bladed screw driver. Two socket extensions and oil filter wrench. Next, you need to get the truck up off the ground so you can work on it. I used ramps to drive up on. To access the oil filter, you need to remove the front skid plate which is accomplished by removing 4 12mm screws which bolt the skid to the frame and 2 10mm screws and a push pin on the front plastic.
There are two metal clips that keep the skid plate on. If you have the truck high enough, the skid will just swing out of the way but since I was only a few feet up I need to remove the skid which requires you to weasel these clips out of the holes.
With the skid removed, you now have access to the oil filter.
The oil pan drain plug can be accessed from a removable panel so you don’t need to remove the rear skid.
To remove the drain plug use your 14mm socket with the longest extension.
The oil filter has a nice little funnel plate that allows you to capture the drips.
Re install your drain plug and note that it doesn’t need a crush washer. Reinstall the filter with a bit of oil around the rubber ring. Put it on hand tight, the rubber seal will swell causing it to become tighter. I used this opportunity to clean up the area before reinstalling the front skid
To install the skid plate, reverse the process you used to take it off. Pour six quarts of oil in, drink the obligatory beer and you are done.
Doesn't everyone? no the tire was still wet from my wash job. just a note, there are some electrical lines running around that area so you need to be gentle witht he spray.
You don't really have to have ramps or use a lifting device -- you can just crawl under the truck and do the work since it's pretty high off the ground. That's what I did, but of course it'd easier with ramps -- I was just too lazy to get them or the floor jack out.
When tightening the filter, be sure that you (other readers) don't mis-interpret the words "hand tight." That means pretty tight -- about 3/4 turn after the gasket contacts the base. It does NOT mean "finger tight" or just barely tight.
Just a thought!
Denis
The oil change did not go smoothly though. I had to remove the rear skid plate to clean/wipe the spilled oil that splashed off when I open the drain plug!!
Options
To me I think its better to draing it after its been sitting all night since most of the oil is in the oil pan.
