SC300 12v Fuel Mod w/ Pictures - FAQ
Old Jun 30, 2007 | 01:48 PM
LyFeWoRx's Avatar
LyFeWoRx
Default SC300 12v Fuel Mod w/ Pictures - FAQ
Mod Location:
The Fuel Pump ECU is located under the driver side rear qtr window.
Reason:
This mod is very easy - I did the mod because I was having Warm Start problems with my SC300, the car would start up then die (This would happen 10+ times in a row) This mod fixed my problem - everything works perfect now. This will also help when I go NA-T , I will have a step by step thread on that as well.
Vehicle Used:
This car is a 1992 SC300, Auto
Total Mod Time:
45 Mins
From MKIV.com
The Problem:
When modifications are made to the car to increase boost pressure and engine breathing ability, some owners have experienced detonation around 4000 rpm, as the 2nd turbo builds boost and comes on line. Usually, this detonation disappears above 5000 rpm. The problem is, the fuel pump is still in "low speed" mode around 4000 rpm's, but the performance modifications have increased fuel demand to the point of "outrunning" the low speed operation. By 5000 rpm, the fuel pump ECU has caught up and switches to high speed operation and all detonation disappears.
The Solution:
There is an easy way around this. You can wire a 12 volt signal directly to the fuel pump, effectively bypassing the fuel pump ECU so that the fuel pump is always in high speed operation. The TT Supra is one of only a few cars that has this dual mode of fuel pump operation, whereas most cars always have 12 volts to the fuel pump. This mod is completely safe. You are basically just turning your complicated fuel system into a basic, Camry style fuel system. You may shorten the life of your fuel pump from say 20 years down to 18 years, but nothing to worry about in the short term. I've personally had mine hooked up this way for over 2 years now without any troubles.
I hope this helps anyone looking to do the 12v fuel mod or starting issues.
Start with the rear seats.
Pull up on the front of the rear seats to remove the bottoms.
Rear seats removed
Remove the 3 bolts holding the rear back panel down. (12mm)
Rear seats removed
Remove 2 push tabs from the panel under the driver side qtr window.
LyFeWoRx's Avatar
LyFeWoRx
Remove a push screw behind the drivers seat belt
Now you can remove the panel
Unclip the fuel pump ecu
All the wires going to the ecu
Clip the Green and Black/Red wires
Strip the 2 wires
Solder the 2 wires together
Tape everything up and re-install the panel and seats.
Old Jun 30, 2007 | 03:32 PM
HTQCummins's Avatar
HTQCummins
I like that fix. Have to wonder, who took the time (and messed up ECU's) to figure that out. Thanks for the post
Old Jun 30, 2007 | 04:40 PM
LyFeWoRx's Avatar
LyFeWoRx
It's pretty easy it has a 12v wire going in from the box and a thick wire going to the fuel pump. Both thick wires hook together. It works out though =)
Old Jul 2, 2007 | 05:38 PM
Blk97SC300's Avatar
Blk97SC300
Thanks for the tip. I just did this "mod", and it only took me about 20 minutes .. I guess it's cuz I've removed the rear seat before. Easy job, and it's a good idea for anyone force inducted (like myself).
Old Jul 2, 2007 | 08:20 PM
vwynn's Avatar
vwynn
JWwhat would happen if you did this mod in a stock Sc400?
Old Jul 2, 2007 | 08:26 PM
revlis240's Avatar
revlis240
nothing (no gain), FPR would return the extra fuel press in the line back to the return line...
Old Jul 2, 2007 | 08:33 PM
LyFeWoRx's Avatar
LyFeWoRx
Yea it doesn't take long to do. Hope the instructions helped a little, it's very easy though.
Old Jul 2, 2007 | 08:35 PM
plex's Avatar
plex
1UZFE/2JZGTE
Nice write up.
Old Jul 3, 2007 | 01:43 PM
ConSynX's Avatar
ConSynX
i had this done and undid it, but i might go back and do it again, as my idle drops to like 400rpm lately, and i'm guessing it might be because of the larger fuel line. . .
curious if this relay is ONLY for the high/low turn on/off.
aka, if i do this 12v mod, will i lose the safety feature where the pump shuts off automatically when the car is off, and after X seconds of priming.
Old Jul 3, 2007 | 01:54 PM
sc250tt's Avatar
sc250tt
yea you might loose it .my car fuel pump dont shut off anymore .funny because on my 92 1j sc400 i did the same mod and it use to shut off after priming
Old Jul 3, 2007 | 04:02 PM
96sc3's Avatar
96sc3
hmm, so is this the right way to do it?
Old Jul 3, 2007 | 04:20 PM
LyFeWoRx's Avatar
LyFeWoRx
Yes, or you can run a 12v wire from the battery to a relay then to the green wire on the fuel pump.
Old Jul 4, 2007 | 01:00 AM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
just fyi the 12 volt mod is for supra TT's because they are one of the few cars that run a 2 stage fuel pump which means it sends 8 volts for low rpm cruising and changes to a full 12 volt for full fuel. well our sc's dont have that so this mod is useless
Old Jul 4, 2007 | 06:48 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
yes they do...
Attached Thumbnails SC300 12v Fuel Mod w/ Pictures - FAQ-fuelecu.jpg
