My Air Suspension OFF light is blinking
Old 05-23-07, 10:23 PM
RXSF
Forum Moderator
RXSF's Avatar
Exclamation My Air Suspension OFF light is blinking (UPDATED)
So the yellow OFF light for my air suspension is blinking periodically while im driving. I checked the manual and it says its okay to keep driving, but to get it checked out my lexus as soon as possible. It says that there is something wrong with the modulated air suspension unit, no idea what that is. Any ideas what may be the problem? hope its not costly, im out of warranty
2004 RX330
Old 05-26-07, 01:32 PM
RXSF
Forum Moderator
RXSF's Avatar
really? nobody knows? bump
Old 05-28-07, 10:26 AM
mandyfig
mandyfig's Avatar
Have you searched the Net?
Old 05-28-07, 08:12 PM
mandyfig
mandyfig's Avatar
I will check with my manual.....
Old 05-28-07, 08:26 PM
dholling13
dholling13's Avatar
All new computers have to cycle 3 times to remove an error code. I would imagine you have already driven the car enough since the problem ocurred for the computer to reset.
When a check engine light came on in one of my cars in years past. The first thing I would do is disconnect the battery and touch the two wires together. Sometimes this resets your computer and it might tell you if this is just a one time faulty sensor error.
Another thing you can always check is the TSB list to see if there's a service bulletin out for your car's suspension.
Old 05-28-07, 09:23 PM
RXSF
Forum Moderator
RXSF's Avatar
hmm thanks. It went away yesterday and came back today, so i dont think its a fluke. THe manual doesnt say much. it just says to stop by your local lexus dealer, but that it is safe to continue driving. Im just afraid the entire suspension module needs to be changed and im out of warranty. Could cost big $$
Old 05-29-07, 09:32 PM
RXSF
Forum Moderator
RXSF's Avatar
well just an update, i made an appointment for next tuesday to bring the car in.
currently, just tonight, it decided to go on "high" mode in the rear but not in the front. great, it looks hideous. anyways, dont know what to do till then. im guessing its safe enough to drive.
Old 06-05-07, 08:54 PM
RXSF
Forum Moderator
RXSF's Avatar
well its tuesday and i got the car back after 6 hours of work. Turns out it was a simple wire that fell off, well and took a lot of time to figure out how to put it back. Labor: $250 Parts: $0
"Found broken wire in the right rear suspension (exhaust solenoid)"
Old 04-11-09, 02:59 AM
brucery
brucery's Avatar
I just started experiencing the same blinking light on the (sports) air suspension of my 2004 RX330. Haven't taken it into the dealer yet, but I'll let you know what they diagnose in my case. Thanks for your posts!
Old 04-12-09, 06:22 PM
Radekn
Radekn's Avatar
I've had the same problem a few months ago , took it to stealership and they found out it was leaking air tank and a sensor, luckily my warranty took care of it. Otherwise it would cost me $ 2600 and some change.
Old 04-14-09, 02:31 PM
shikbas
shikbas's Avatar
what are the terms of the warrenty for the air suspension thanks
Old 04-14-09, 11:41 PM
RXSF
Forum Moderator
RXSF's Avatar
warranty is the usual: 4 years, 50K miles unless you bought the extension
RoGX
GX - 1st Gen (2003-2009)
09-01-24 06:20 PM
sicklexo
04-30-12 02:21 PM
markpaco
05-31-07 11:08 PM
5UK1
02-12-07 12:31 AM
mbaek
RX - 1st Gen (1999-2003)
08-11-03 12:19 AM
Quick Reply: My Air Suspension OFF light is blinking
