Oil Change on a LS460/LS460L..
Old 04-09-07, 09:41 AM
joedaddy1
joedaddy1's Avatar
Talking Oil Change on a LS460/LS460L..
Ok.. I didn't take pictures.. but this car is pretty simple.
The oil filter is on the driver side.. if you look at the underbody of the car there's a little door/flap that you remove one screw to open. In there you'll see the filter. You do NOT need a special to get the filter off.
They do have a tool @ lexus.sst.com that fits the filter perfectly. I might get that part soon, seems like it would be a bit easier with it. The tool is $30!
The oil drag plug is the same as any other car. Towards the passenger side of the car. I put in 9 quarts of Mobil1 5w-20 (5 quart jug is $24 @ wal-mart)
The manual says 9.1 quarts, but you can bet you probably didn't get the last .1 quart out of the engine anyways.
Oil filter Part # is 04152-38010 . I think this filter is specific to the LS460 ONLY. So IS250/350/ES350/RX350/ SHOULD NOT FIT..
The filter is $8 from irontoad.com or $14.50 @ your local dealership.
IT MIGHT BE IN MY HEAD, BUT the car is MUCH quieter after the oil change.
this might be because, 1. the lexus dealer changed the oil with regular 5w-30 oil @ the 5000 miles service. Our manual recommends 5w-20, 0w-20.. Well Toyota only has Synthetic 0w-20 (not sure about 5w-20).. So put 2 and 2 together, our cars seem like it "needs" synthetic oil. If you disagree oh well.
Also.. Found out our car has TWO air filters.. the part # is 17801-38010 .. buy TWO @ a time. It's $23 @ irontoad.com and $38 at the dealership. EACH.
For those of you that don't change the oil yourself, PLEASE MAKE SURE YOUR DEALERSHIP USE 5w-20 in warm areas, and 0w-20 in cold areas~.. why do I say this? because there's a TSB out for IS350 to NOT use 5w-30, i guess it messes with those engines, so I am guessing the same thing COULD apply to the LS460.
That is all..
Old 04-09-07, 12:04 PM
Craig B
Craig B's Avatar
Doesn't the manual say to use OW20 for best fuel economy?
Thanks for the info...
Craig
Old 04-09-07, 05:49 PM
Craig B
Craig B's Avatar
Default Most likely,
the RX 400H
Craig
Old 04-09-07, 08:15 PM
joedaddy1
joedaddy1's Avatar
Craig
yea.. if you look @ the cap it says 0w-20 or 5w-20..
i figure if it snows where you live 0w-20 is the way to go..
but I live in SoCal where it's pretty "warm" temperature year around, so i went with 5w-20..
also.. UPDATE: that smoother sounding thing was all in my head.. ha
CamelKool (04-29-21)
Old 04-09-07, 09:57 PM
Johnny
Johnny's Avatar
Good tips. Yeah, it would sound quieter and smoother after the oil change, just as it seems to carve the wind better after a wax job. Must have something to do with elbow grease...
Old 04-11-07, 12:24 PM
VIPLexus
VIPLexus's Avatar
In Lexus of Austin, we use 5W-30 for all the cars. But for the LS460, we use 0W-20.. And yes, it is hot here in Texas..
CamelKool (08-06-20)
Old 04-11-07, 07:32 PM
joedaddy1
joedaddy1's Avatar
good to know that.. thanks for the confirmation..
Old 04-11-07, 07:50 PM
Nospinzone
Forum Moderator
Nospinzone's Avatar
VIP, do you know why they go with the lighter oil for the LS 460?
Old 04-11-07, 07:53 PM
Nospinzone
Forum Moderator
Nospinzone's Avatar
Hey! With that post I just graduated to a Rookie! The drinks are on me!
Old 04-12-07, 03:34 AM
Craig B
Craig B's Avatar
The owners manual says the lighter weight oil is for better fuel economy.
Craig
Old 04-12-07, 03:17 PM
Nospinzone
Forum Moderator
Nospinzone's Avatar
Craig
Thanks, Craig.
Personally though, I would rather get improved engine protection than an extra .1 mpg fuel economy.
DrQuality (08-07-21)
Old 07-31-07, 12:25 PM
joedaddy1
joedaddy1's Avatar
Originally Posted by 460LEX
What about the filter drain tube, did you use it to drain the filter before taking it off.? It should have came with filter.
yes it did and yes i did
Old 02-20-09, 03:35 PM
shuguley
shuguley's Avatar
Are there any special considerations or procedures for changing the oil filter?
Old 02-26-09, 10:36 AM
slickc6
slickc6's Avatar
Default Oil filter location
I can't seem to find the oil filter. I have looked at the underbody of the car (drivers side), but I cannot find the little door/flap that you describe. Can anyone help me?
Old 02-26-09, 02:17 PM
jlawr
jlawr's Avatar
This photo will show you the oil is draining after the cover has been opened. I hope this helps you locate it:
File Type: pdf
Quick Reply: Oil Change on a LS460/LS460L..
