TPMS compatibility question????
Old 03-13-07, 11:43 AM
Phanatik
Phanatik's Avatar
Default TPMS compatibility question????
Is there any way (modifications) to make non-compatible wheels compatible? If not, is there any way to disable the sensors or to make the warning light go away and just not use them anymore? I tried searching for some info on this but couldn't find a definite answer. Thanks a lot in advance.
sinister2c
sinister2c's Avatar
barrel bands to strap the sensor inside the wheels.
Old 03-13-07, 11:48 AM
menech
menech's Avatar
Any good wheel shop can drill a second "dummy" valve stem hole in the wheel to mount just the sensor.
Old 03-13-07, 04:09 PM
Phanatik
Phanatik's Avatar
So if you drill a second "dummy" valve stem hole in the wheel to mount just the sensor, then the sensor would work perfectly? Is that all they have to do? Would the wheel shops do that?
tucker21
05-19-16 05:26 PM
BieberNutz
Wheels, Tires & Brakes Forum
01-01-16 01:03 PM
CharlieVo
03-23-14 08:39 PM
revspeed
09-13-06 12:52 PM
zerohero
17
05-17-06 05:41 AM
Quick Reply: TPMS compatibility question????
