Hey guys, I have a 97 SC300- I'll be swapping it to a 5spd this weekend. Within a month, I will install a T67 turbo, along with a thicker head gasket (OEM supra TT, lowering compression to 9.0:1), and tune with a MAP ECU. The stock rev limiter is pretty low (6,250 or 6,500.. not exactly sure). Some extra room to rev in each gear would be kinda nice to have...
Is there any way to raise the limiter? I have a manual tranny ECU by the way- not sure if it makes a difference though. Is there a way we could possibly rev to 7,000? Maybe even 7,500? I tried searching, but nothing came up. Any thoughts or suggestions would be great, thanks in advance.
the emange ultimate claims that it can alter rev limit (there might be other piggybacks, but i'm not sure) although i don't now if anyone has done on an sc300 and see if that function actually works, otherwise it will take a stand alone.
Has anyone in here "overclocked" the ECU? I had someone overclock the ECU on my 3000GT VR4 by 10%- raisining the limiter to 8,000 rpm. All that needed to be swapped was a single little crystal on the ECU's board.
The Rev limiter is set for reason. Changing it without changing the fuel map and other misc parts harms the car and makes it starv for fuel cause it is going past the fuel cutoff! My suggestion is look for a ECU reflash they usually add higher revs and change the fuel map and other misc parts. Other then that if you want to change it you need to get it dynoed so they can reflash the ecu and the fuel map so it compinsates for the add revs!
Hope this helps good luck! Also post detailed pics of the swap with instructions. As I mentiond to you that I wanted to do the swap this summer and it would be nice to get some references.
*****Do not buy from this member until further notice *****
you wont need the extra rev you'll have a turbo i dont thin you will get very much lag the tt head gasket wont lower your compression to 9:1 boost first then worry about if you need more. baby steps dont blow your motor
im curious too. because im gonna be turboing my car any time, and running a t70 with fuel and all the jazz. but im gonna be running map-ecu2 and increaseing reves to atleast 7k would be nice
I ordered a boostlogic 2.5mm head gasket, so my compression will be 8.5:1.
I believe the rev limit on a manual sc300 is 6800rpm- so I think that should be fine. I thought it was the same as the auto rev limiter. Could anyone verify this?
