How to increase the stock rev limiter?
Old Mar 5, 2007 | 11:58 PM
Blk97SC300's Avatar
Blk97SC300
Default How to increase the stock rev limiter?
Hey guys, I have a 97 SC300- I'll be swapping it to a 5spd this weekend. Within a month, I will install a T67 turbo, along with a thicker head gasket (OEM supra TT, lowering compression to 9.0:1), and tune with a MAP ECU. The stock rev limiter is pretty low (6,250 or 6,500.. not exactly sure). Some extra room to rev in each gear would be kinda nice to have...
Is there any way to raise the limiter? I have a manual tranny ECU by the way- not sure if it makes a difference though. Is there a way we could possibly rev to 7,000? Maybe even 7,500? I tried searching, but nothing came up. Any thoughts or suggestions would be great, thanks in advance.
-Allen
Old Mar 6, 2007 | 02:07 AM
WDoherty's Avatar
WDoherty
the emange ultimate claims that it can alter rev limit (there might be other piggybacks, but i'm not sure) although i don't now if anyone has done on an sc300 and see if that function actually works, otherwise it will take a stand alone.
Old Mar 6, 2007 | 10:12 AM
Blk97SC300's Avatar
Blk97SC300
Has anyone in here "overclocked" the ECU? I had someone overclock the ECU on my 3000GT VR4 by 10%- raisining the limiter to 8,000 rpm. All that needed to be swapped was a single little crystal on the ECU's board.
-Allen
Old Mar 6, 2007 | 10:29 AM
cip's Avatar
cip
I do believe the Ausse's have addressed this one before...
http://planetsoarer.com/ecu/ecu.htm
TRDRacer's Avatar
TRDRacer
The Rev limiter is set for reason. Changing it without changing the fuel map and other misc parts harms the car and makes it starv for fuel cause it is going past the fuel cutoff! My suggestion is look for a ECU reflash they usually add higher revs and change the fuel map and other misc parts. Other then that if you want to change it you need to get it dynoed so they can reflash the ecu and the fuel map so it compinsates for the add revs!
Hope this helps good luck! Also post detailed pics of the swap with instructions. As I mentiond to you that I wanted to do the swap this summer and it would be nice to get some references.
Old Mar 6, 2007 | 07:49 PM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
you wont need the extra rev you'll have a turbo i dont thin you will get very much lag the tt head gasket wont lower your compression to 9:1 boost first then worry about if you need more. baby steps dont blow your motor
Old Mar 6, 2007 | 08:17 PM
vwynn's Avatar
vwynn
changing your cam shaft will it increase revs or lower rev limit?
Old Mar 6, 2007 | 09:30 PM
1sxyrxy's Avatar
1sxyrxy
im curious too. because im gonna be turboing my car any time, and running a t70 with fuel and all the jazz. but im gonna be running map-ecu2 and increaseing reves to atleast 7k would be nice
Old Mar 6, 2007 | 11:56 PM
Blk97SC300's Avatar
Blk97SC300
I ordered a boostlogic 2.5mm head gasket, so my compression will be 8.5:1.
I believe the rev limit on a manual sc300 is 6800rpm- so I think that should be fine. I thought it was the same as the auto rev limiter. Could anyone verify this?
-Allen
Old Mar 7, 2007 | 01:21 AM
dejacky's Avatar
dejacky
Revving too high on a stock 2jz-ge head will float your valves = destruction.
Old Mar 7, 2007 | 02:03 AM
qksl2's Avatar
qksl2
What is too high?
Ian
Old Mar 7, 2007 | 07:06 AM
sc250tt's Avatar
sc250tt
word if you want to rev high get a 1j and call it a day
Old Mar 7, 2007 | 08:12 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
Originally Posted by Blk97SC300
...the rev limit on a manual sc300 is 6800rpm... Could anyone verify this?
That's where mine kicks in. The T61 is just pouring on power straight up to cutoff were my peak h.p. numbers hit, so there's more if it went to 7000.
Now running a Supra TT obd1 ecu, though the SC300 ecu was same rpm cutoff.
Old Mar 7, 2007 | 10:09 PM
1sxyrxy's Avatar
1sxyrxy
6800 for you guys?. mine is like 6200
Old Mar 8, 2007 | 12:17 AM
qksl2's Avatar
qksl2
Yeah 6800, tested at the track tonight. Anyone know what the safe rev limit of the stock head is?
Thanks!
Ian
