Help! 20” Wheel width/offset advice GS350AWD
Old Dec 31, 2006 | 11:28 PM
MKIV98TT's Avatar
MKIV98TT
Default Help! 20” Wheel width/offset advice GS350AWD
I’ve looked at just about every wheel post in this 3rd Gen GS forum but am still confused when it comes to what wheel width and offset to go with. It seems like all 20” wheels are custom and are build to order so I want to be completely sure my specs are inline before ordering a set of wheels.
The car just hit 1k mikes and I have already installed the Tanabe NF springs and do not plan to go any lower then that. I also do not plan on upgrading my brakes in the future.
My goal is to get the widest wheel I can fit with the most aggressive offset I can. I do know that I may have to either roll or cut the inner fenders in order to not rub…..that’s not a problem. I want to be aggressive without rubbing.
I see that many GS owners have gone with 20x8.5 in the front and 20x10 in the rear. Is it possible with little to no inner fender mods to go beyond that size? I was thinking a 20x9 or 9.5 in the front and a 20x10.5 or an 11 in the rear. What are my options? It would be great to get some feedback before dropping $4k on custom wheels. Thanks!
Old Jan 1, 2007 | 09:36 AM
Ice350's Avatar
Ice350
There is lots of room in the wheel wells the the 3GS but it has limits. If you want 20x9 up front I'd say offset should be around 36-38.
For the rear with 20x10, around 40 offsett.
Old Jan 1, 2007 | 10:23 AM
MKIV98TT's Avatar
MKIV98TT
Would you go beyond x10 in the rear? With the offsets you recommended....would the wheel sit flush with the fender and will I have to make any body mods? Thx!
Old Jan 1, 2007 | 11:39 AM
Ice350's Avatar
Ice350
I'm a little conservative and don't believe in cutting on a 50K+ car for a little extra bling. I have 19x8.5 all around and I can see 9.5 or 10 would be okay. Plus you have your car lowered. I'm pretty sure with 20x10.5 you would have to make some kind of fender modding to make that work. Unless you use a really skinny rubber band tire. If that's okay with you, that's fine....but I wouldn't do it...especially since we ride passengers in the back seat. You should be able to get 10.5 under there as long as you're willing to cut and pull. Heck, I saw a kid with 22's on his GS. He told me he cut the thing to pieces to make it work. He gave me the the perfect reply. He said, I'm a kid...I wouldn't do it if I was a grown man like you.
Old Jan 1, 2007 | 01:07 PM
MKIV98TT's Avatar
MKIV98TT
Do you have any pics of your car I could see? I was shooting for an aggressive tough look and was ok with having the fenders rolled by a professional. Other then a little fender mods what do you think about running x9.5 in the front and x10.5 in the rear? And what offset should I be running? Do most people find the offset by trail and error?
I found this post by JKashat
I would say 20x8.5 +38 front and 20x10.5 +45 rear with 245/35/20 and 275/30/20 tires. You could actually fit a 20x9 up front and an 20x11 in the back with 255/30/20 and 275/30/20 (not 285, too tall) if you weren't planning on the drop.
What do you think about these specs?
Old Jan 1, 2007 | 05:38 PM
Ice350's Avatar
Ice350
Here's a link to pics of mine. They're 19x8.5 all around with 35 offset. The wheels sit flush with the fenders.
Why do you want 9.5 in the front. Someone with more mechanical experience needs to comment but I don't think that's wise. I guess you could do it but why? This is a Lexus, not a chevy monte carlo. It can look really good and you can push the envelope but this type of car demands class and care imo. With that size up front, I'd be concerned how much wear and tear I'd be putting on the power steering pump. It wasn't designed to handle the stress and weight you're planning. I don't know...I'm out of this conversation. Good luck.
https://www.clublexus.com/forums/sho...d.php?t=255680
Call the guys at my favorite wheelshop for advice 954-771-4508...ask for Dave.
Old Jan 1, 2007 | 07:47 PM
MKIV98TT's Avatar
MKIV98TT
Nice car....well done on your wheel choice. Thanks for all the info reggiek.
You're giving me all the good info I need to make my decision. I'm totally fine with running 8.5's. I'm just gathering all the info I can get before making the purchase. I'm just trying to look at all the options so that I'm not dissappointed later on. How can I verify that these offsets are the ones to go with? 20x8.5 +38 front and 20x10.5 +45
Old Jan 1, 2007 | 10:59 PM
MKIV98TT's Avatar
MKIV98TT
Are the wheel offsets the same for the 2006+ GS300, GS350 RWD & AWD, and GS430?
Old Jan 3, 2007 | 03:22 PM
scottsevas's Avatar
scottsevas
Default 20' staggard
check out the gs on the site:
www.sevaswheels.com
Old Jan 3, 2007 | 03:46 PM
IS_250's Avatar
IS_250
the offsets should all be the same. the only thing you should be worried about is tire sizing. from what ive seen, its best to keep the overall diameter as close as possible for the AWD models
Old Jan 3, 2007 | 03:48 PM
Ice350's Avatar
Ice350
www.sevaswheels.com
Welcome to clublexus. Do you work with Carl? I drove down a few weeks ago in the rain to buy the black s stars on the GS in the link above.
Old Jan 3, 2007 | 05:09 PM
D2-AUTOSPORT's Avatar
D2-AUTOSPORT
Former Sponsor
What wheels are you purchasing and is the shop handling the specifications or are you doing it yourself?
Old Jan 3, 2007 | 06:58 PM
MKIV98TT's Avatar
MKIV98TT
So if I go staggered, and be sure to keep the overall diameter w/tires the same I will not screw up my AWD drivetrain?
Old Jan 3, 2007 | 06:59 PM
MKIV98TT's Avatar
MKIV98TT
www.sevaswheels.com
What size wheels are on that blue GS? This is the exact look I'm going for. Can I get those wheels apinted silver?
Old Jan 3, 2007 | 07:02 PM
MKIV98TT's Avatar
MKIV98TT
I'm still trying to decide between the iForged or Work wheels. I know I want to go with a 20" wheel. I'n just not sure when it comes to the width/offset. I want to be aggressive, but not too aggressive where I get some frequent rubbing.
