Navigation Hack Alternative - Hybrid Nav DVD
Old Dec 9, 2006 | 06:14 PM
  #46
Technique's Avatar
Technique
CL Folding 500,000
FYI, I don't like the software override... I think that having to enter the service menu every time I start the car is unacceptable... So, check my webpage for details on what I did to have a switch that instantly overrides the destination entry lockout...
Here's the exact page:
http://www.infoarena.com/lexus/navhack/
You can do this on a 2006 or 2007, on ANY version of the DVD NAV V5.1, V6.1, firmware whatever, doesn't matter, works on all of them like a charm
Old Dec 10, 2006 | 07:14 PM
  #47
IS_5SPD's Avatar
IS_5SPD
Can't wait to see what v7.1 (or whatever the update will be called) will do. Will we have to wait for the 2008's to arrive, or is there a possibilty that newer editions of the '07 will have an updated Nav version?
Old Dec 10, 2006 | 07:28 PM
  #48
Technique's Avatar
Technique
CL Folding 500,000
Well, don't confuse the DVD version (V5.1, V6.1) with the NAV version (Gen 3, Gen 4, Gen 5)
The new DVD version, V7.1 or whatever, will just be new map data, for the most part...
The big change will be when the Gen 6 navigation unit comes out. I wonder what's in the LS460. I am pretty sure it uses a hard drive but I don't know if it's GEN 5 nav or not...
Old Dec 11, 2006 | 12:07 PM
  #49
malon015's Avatar
malon015
Technique:
Great work.
I have a 2007 IS250 with V6.1 Nav DVD, 1650 Firmware. I also own a 2004 Lexus RX330 with V4.1 Nav DVD. Will the V4.1 "loading.kwi" file work as my firmware file with the V6.1 maps?
Old Dec 11, 2006 | 12:16 PM
  #50
sickntired's Avatar
sickntired
I believe the LS 460 has a variant of Eclipse's AVN7000 which also has a hard drive. It is probably a variant of the Gen 5 system.
http://www.eclipse-web.com/7000index.html
Malon015: won't work unfortunately. I believe your RX 330 is Gen 3 and you would need a disk from another Gen 2-3 system (I believe these were compatible).
Old Dec 11, 2006 | 12:23 PM
  #51
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Originally Posted by malon015
Technique:
Great work.
I believe your RX has a Gen 3 or 4 nav, not a Gen 5.
Old Dec 11, 2006 | 02:33 PM
  #52
Technique's Avatar
Technique
CL Folding 500,000
Technique:
Great work.
It might "work", but not worth trying, as it will probably barely be functional... You gotta stay with GEN 5 firmware... So V5.1 is your only option...
Old Dec 12, 2006 | 12:04 AM
  #53
ecalica428's Avatar
ecalica428
wilol a version 4.2 will work or only ver 5.1?
Old Dec 12, 2006 | 04:51 AM
  #54
Technique's Avatar
Technique
CL Folding 500,000
Only V5.1.......
Old Dec 12, 2006 | 02:53 PM
  #55
Technique's Avatar
Technique
CL Folding 500,000
FYI, I noticed one "inconvenience" of the switch method... When I switch the override on, and I can enter destinations, it only works for, oh 30-60 seconds... Then it locks it out again... I have to flip the switch off and on again, and then I can enter destinations once again... So, I guess if you are going to enter a specific destination, the switch is fine... If you want to browse the POIs for a while, then use the software override... I like having both options
Old Dec 12, 2006 | 05:43 PM
  #56
BottomsUp's Avatar
BottomsUp
You mention jumpy nav in that link when the hack is enabled. Is this true for everyone or intermittent? I guess i'm wondering if this is a guarenteed to have side effect of performing this mod. I really want to enable MP3 folder listing while driving on my '07.
TIA
Old Dec 12, 2006 | 05:50 PM
  #57
Technique's Avatar
Technique
CL Folding 500,000
TIA
The standard nav hack does NOT have jumpy nav and gives you the following:
1) mp3 folder while driving
2) DVD movies while driving
3) bluetooth phone dialing while driving
Old Dec 13, 2006 | 09:26 AM
  #58
SGT's Avatar
SGT
Technique, great job in spreading the word. Keep up the good work.
Old Dec 14, 2006 | 05:20 PM
  #59
ES3's Avatar
ES3
Wish I had both discs... they swapped my original after I was having location problems.
Old Dec 19, 2006 | 08:02 PM
  #60
istundra's Avatar
istundra
THank you technique. you are alot of help.
I inserted the hybrid disc I have made ~_^ and it does not read.
It says "Unable to Read Map Disc"
so i pressed eject and tried again. Nothing happen.
DId you remember seeing this in your 07?
