Installing an after market radio in a 1995 LS 400
Old Jun 27, 2006 | 04:14 PM
lucent_min's Avatar
lucent_min
Question Installing an after market radio in a 1995 LS 400 (HELP ME!!!!!! PLEASE!!!!!)
Would someone please tell me or show me the wiring code or diagram for a Lexus Nakamichi Sound system. I’m trying to put in an aftermarket radio in a Lexus LS 400 1995 and I would like to know each wire color code including how to make my power antenna work with the after market radio if possible. Primarily I need to have all speakers functioning less the center sub woofer with the after market radio.
"Please can someone assist me????"
Old Jun 29, 2006 | 09:49 AM
JRB1449's Avatar
JRB1449
I just used the cut one and test method. I removed the faatory amp from under the passenger seat and using a ohm meter check the wires continuity and also did the same with the wires for the speakers......takes a long time but I got it done. Works like a champ!!! I have a pioneer DEHp- 9300.
It was one of the hardest installs I have done.
Old Jun 29, 2006 | 10:44 AM
lucent_min's Avatar
lucent_min
I started to do what you just stated but time is what Im worried about. There has got to be an easier way to make the connections. You are on point and I really appreciate it.
Old Jun 29, 2006 | 12:09 PM
PVSLS400's Avatar
PVSLS400
metra make a harness dont cut wires
Old Jun 29, 2006 | 12:18 PM
lucent_min's Avatar
lucent_min
Metra.com? Is it for a 1995 edition?
Old Jun 29, 2006 | 12:24 PM
PVSLS400's Avatar
PVSLS400
Yes all years but you need a deck that has front rear and sup pre outs
LEXUS
LEXUS ES 300 1999 2001 99-8155 99-8155 99-8155 70-8113
LEXUS ES 300 1997 1999 99-8155 99-8155 99-8155 70-8112
LEXUS ES 300 1992 1996 99-8150 99-8150 99-8150 70-8112
LEXUS ES 250 1990 1991 88-00-9000 88-00-8000 88-00-8000 70-1761
LEXUS GS 300/400/430 1998 2003 99-8152 99-8152 99-8152
LEXUS GS 300/400/430 1993 1997 99-8154 99-8154 99-8154
LEXUS GX470 2003 2006
LEXUS IS 300 2001 2005 99-8151 99-8151 99-8151 LEXUS LS430 2001 2005
LEXUS LS400 1995 2000 99-8153 99-8153 99-8153
LEXUS LS400 1993 1994 99-8156 99-8156 99-8156 70-8112
LEXUS LS400 1990 1992 99-8156 99-8156 99-8156 70-1761
LEXUS LX470 1996 1997 70-8112
LEXUS SC 300/ 400 1992 1999 70-8112
www.metraonline.com
click on the application guide on left middle of screen you will see list like i posted dont use fit guide it wont work
Old Jun 29, 2006 | 12:33 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
even with the metra harness i do believe you will lose functionality of the rear sub.
and if u decide to replace the rear sub with a full system pleae let me know, il buy the Nak sub off you.
Old Jun 29, 2006 | 12:56 PM
lucent_min's Avatar
lucent_min
When I go to that site for the purcahse of that unit, It dosent give me the option for my vehicle (LS 400 1995). Which unit I get for my vehicle. Im not using the center sub simply because Im installing a whole new sound system in my vehicle. I just want the after market radio to have access to all 6 standard door and tweeter speakers. As far as the factory center rear sub, I don't have that any more because that speaker blew on me about a year ago. I've installed an after market sub that would be support by and after market amp.
Old Jun 29, 2006 | 01:09 PM
lucent_min's Avatar
lucent_min
(UPDATE) I just called metra VIA telephone and they don't carry a radio after market harnest for my vehicle (LEXUS LS 400 1995). I need help guys! I want to install this after market radio but don't want to cut and search for the correct wires to make it work. A harnest would work perfectly. Can someone tell me which color is the battery positive (12V) for the radio? When I turn on the vehicle, I should be able to turn on the unit. And when I turn the vehicle off, it should go off as well automaticly like the factory and not lose any memory. Which color wire supports that ?
Old Jun 29, 2006 | 01:18 PM
PureDrifter
BahHumBug
CL Folding 100,000
thats wierd, on the application guide (PDF) i found the no. for the dash kit but not the wire harness.
LS400 1995-2000 dash install kit part no.99-8153
Old Jun 29, 2006 | 01:30 PM
lucent_min's Avatar
lucent_min
Nope, I called and they told me that they don't carry that harnest for my vehicle.
Old Jun 29, 2006 | 11:24 PM
PVSLS400's Avatar
PVSLS400
I will make a call to my distributor they just came out with a brand new one for the 93 that was great easy and just simplified the system all it had was red, black,yellow, 1 remote, 1 power antenna and 4 pre outs rca's and was told they were going to do this in the 95-00, 2 months ago. it might not be available for retail yet. and yes you lose factory sub must put in aftermarket amp or splice but if you splice you lose all eq for sub
Old Jun 29, 2006 | 11:39 PM
PVSLS400's Avatar
PVSLS400
PART # 70-8112
1992-1999
Toyota
AMP Integration Harness
http://www.metraonline.com/_assets/m...NST70-8112.pdf
this is what i have in my ls
Attached Thumbnails Installing an after market radio in a 1995 LS 400-70-8112.jpg
Old Jun 30, 2006 | 02:11 AM
lucent_min's Avatar
lucent_min
I've seen that harnest before and I was told that it wouldn't fit mine because I have a Nakamichi system which is a 14 pic connection. The harnest you have on display is a 15 pin connection.
You are the man though for trying to help me get the information I need . I really appreciate it man but I don't know what I'm going to do now .
Old Jun 30, 2006 | 02:42 AM
PureDrifter
BahHumBug
CL Folding 100,000
more than likely ur juss gunna end up elbow deep in the dash soldering/crimping by hand. nobody makes a WIRING kit for our cars but hey, isnt custom wiring cheaper than a custom dash kit. GL
