Belt maintenance diagram
Old 06-23-06, 08:24 PM
lexusk8
lexusk8's Avatar
Lightbulb Belt maintenance diagram
FYI, I found this informational diagram on general belt maintenance, involving the V-belt, serpentine and timing belts. This was sourced from the Dayco products website. Very helpful for us DIY'ers
Old 07-14-06, 09:43 AM
eman88
eman88's Avatar
do you have any info on how to replace the V-belt on a GS430
Old 07-14-06, 10:13 AM
Tammy
Tammy's Avatar
I may be mistaken, but ,a GS430 has a serpentine belt and no V-belt?
Old 07-14-06, 10:39 AM
lexusk8
lexusk8's Avatar
Tammy is right. The GS430 has a serpentine belt, not a V-belt. In order to remove the existing belt, you'd have to unscrew the bolt at the center of the belt tensioner, which then releases tension holding the drive belt, and then you can remove the belt itself. I believe this removal process is universal among all car models.
For your reference, in the GS430 pic below, #1 is the serpentine belt, and #2 is the belt tensioner.
Old 07-28-06, 10:13 AM
JCtx
JCtx's Avatar
Just curious: How do you put the right tension back?
Old 07-29-06, 06:59 PM
Dx3
Dx3's Avatar
The tensioner does that automatically.
Jonny
Old 07-30-06, 12:56 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
how do you do it on a gs300?
Old 07-30-06, 01:07 PM
GSteg
GSteg's Avatar
Same method but instead of turning the tensioner pulley counterclockwise like on the V8s, you turn it clockwise. Once it's turned, you can just slip out the belt. Very easy installaion. I rather do this all day than do oil changes
BTW..i changed this on my car a few days ago using GoodYear Gatorback belts. Its designed to decrease noise and squeeks, while promoting longer belt life. I can honestly say this belts is better than OEM, while costing a few bucks less. My car is finally quiet (at least for a V8 ). I use to have squeeks in the morning and my belt would over power my stock exhaust noise. LOL!
__________________
1999 Lexus GS400
-Stock
Your user account may not have sufficient privileges to access this page.
Old 07-30-06, 10:28 PM
FunGuy
FunGuy's Avatar
Here is what I did to my car. Hope it helps. It only took me 1min. If any longer, then you know you are doing something wrong. Post some pics of your car man, want to see your wheels.
Old 07-31-06, 12:52 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
FUNGUY i will have some pics up for you in a few days! ! !
Old 08-03-06, 07:16 PM
lexusk8
lexusk8's Avatar
Thumbs up Changed the drive belt
After 126,000 miles in the ES, I decided it was time to change out the drive belt that drives the A/C compressor and the alternator. The squealing noise that's emitted every morning when I start the car is getting bothersome, but after changing the old belt out with the Goodyear Gatorback belt, the difference is very noticeable. Not only is the belt area more quiet, the air conditioning feels much cooler than before I'm sure it has a lot to do with the integrity and durability of the new belt. Plus, the old belt has numerous small cracks and minuscule pieces missing across the ribs. It was definitely that time to change the belt, and the job only lasted 20 min. All you need are 10 and 12mm sockets and wrenches of different lengths.
Old 12-06-07, 06:11 PM
AB Boater
AB Boater's Avatar
Bless you for posting this diagram!! You saved me a lot of hassle.
Old 02-22-08, 11:18 AM
lexluger71
lexluger71's Avatar
g steg is that all u did to change the belt, how much did the belt cost
BayAreaLex
10-14-15 02:02 PM
dadoody
06-23-14 08:05 AM
Silvermtb6
07-05-11 05:35 AM
lyonkster
10-24-09 06:10 AM
Gunbelt
02-17-08 04:32 PM
Quick Reply: Belt maintenance diagram
