Extended Wheel Studs part #?
Old Mar 10, 2006 | 01:56 AM
Sc1UZ-FE's Avatar
Sc1UZ-FE
Default Extended Wheel Studs part #?
Hope I put this in the right place....Well I need a part Number on Extended Wheel Studs And Manufacturer!
I Put on my Ls400 Brakes and thats why I need it
Thanks
Zee
Old Mar 10, 2006 | 02:55 PM
ACleanSC4's Avatar
ACleanSC4
You need spacers to go with those extended studs right?
Check H&R 15mm spacers, they come with extended studs as well as a spacer. Or if you go larger, they have adaptors which have built in studs...
Old Mar 10, 2006 | 02:59 PM
JspecSC3's Avatar
JspecSC3
I know this might be a little off topic but who makes those ITBs for the 1UZ on your signature and where did you get them?
Old Mar 10, 2006 | 03:27 PM
AME_VIP's Avatar
AME_VIP
I was wondering where to get extended studs as well. I know H&R has them.
I read in an old thread that someone contact H&R directly and they sold the studs seperately. (extended by 15mm)
Old Mar 10, 2006 | 06:34 PM
Sc1UZ-FE's Avatar
Sc1UZ-FE
http://www.1uzquadcam.co.nz/
Old Mar 10, 2006 | 06:37 PM
Sc1UZ-FE's Avatar
Sc1UZ-FE
I just need a 6mm spacer and extended wheel studs. I have 18" rims and it didnt fit right with the ls400 brakes....
Old Mar 12, 2006 | 03:00 AM
Sc1UZ-FE's Avatar
Sc1UZ-FE
Someone Got to know....
Old Mar 16, 2006 | 12:45 PM
SCSpeed's Avatar
SCSpeed
If you're in Ca, go to Kragen Autopart and order the studs. The shorter one is the stock SC400 stud, and the longer one is Kragen studs. The part number is on the nylon bag. They work perfectly on the front of my SC. Each costs $3 and is the cheapest that I've known.
Old Mar 16, 2006 | 03:29 PM
AME_VIP's Avatar
AME_VIP
For those that don't have Kragen, do you know the specs on the splines, length, etc ?
Old Mar 17, 2006 | 10:13 AM
DETUNED's Avatar
DETUNED
ARP makes extended wheel studs for the supra. they will fit your sc as well.
Old Mar 17, 2006 | 06:13 PM
AME_VIP's Avatar
AME_VIP
great info thanks!
Old Mar 19, 2006 | 11:23 PM
Sc1UZ-FE's Avatar
Sc1UZ-FE
Went to the arp site and cant find a part number for the supra. Just honda's Studs.
Thanks SCSpeed For the info....
Old Mar 20, 2006 | 05:31 AM
DETUNED's Avatar
DETUNED
Titan motorsports carries them. give them a call 407-277-8423
Old Jun 20, 2008 | 11:04 AM
sweetchuck's Avatar
sweetchuck
arp-100-7715 $35.69 a pack of 5
Old Jun 23, 2008 | 12:59 PM
FormosaSC's Avatar
FormosaSC
ouch! expensive...
