Preventing wheelhop - Coilover settings?
Old Feb 23, 2006 | 03:27 PM
SPORTcoupe's Avatar
SPORTcoupe
Default Preventing wheelhop - Coilover settings?
I went to the track for the first time with my new coilovers, and by recommendations of a friend, I set them to full soft (dampening) for the first run.
I ended up getting horrible wheelhop and netted a 2.3 sec 60'
After adjusting the dampening to full hard, there was a LOT LESS hop, and a 1.9 sec 60' was attained.
I was told after my passes that my tires were waaay overinflated (~26 psi), so I'm going to lower the pressure quite a bit more next time, but I'd still like to know what the rear (and front) coilovers should be set to.
They're Tein FLEXs if it makes any difference.
To answer some questions that might come up: I'm on 285/40-17 street tires, and I'm slipping the clutch slightly at 4K rpm. I'm using spark-cut 2-step rev limiter, which spools me to about 3.5 Psi off the line. Next time out I'll most likely be on 275/40-17 BFG DRs.
Cheers,
~Alan
Old Feb 23, 2006 | 05:47 PM
JspecSC3's Avatar
JspecSC3
How many pounds of boost are you pushing throughout the entire run? What PSI is recomended for the rear tires? I would really like to see your car at the track one of these days. Hey why dont you come with us to our track day on Saturday the 25th at Sacramento Raceway?
Old Feb 24, 2006 | 03:03 AM
rscott's Avatar
rscott
stiff rear/soft front. that will give you maximum weight transfer to the rear for traction. also, if thats not enough, you can unbolt the front sway bar endlinks and pull off the bar to get a little more lift in front.
as far as psi goes on a street tire 26psi is waaaaay too high. the right pressure to run really depends on the tire as far as sidewall characteristics but usually sub-20 is a good range. better too high than too low though...if you go too low you run the risk of tearing your sidewall. thats badnews =)
Old Feb 24, 2006 | 08:21 AM
poser714's Avatar
poser714
Hmmm thats interesting.. i always thought it was better to have the car stiff in the front and softer in the rear so when the weight transfers to the rear, the suspension will dampen and create more traction for the rear tires???
Old Feb 24, 2006 | 09:01 AM
SPORTcoupe's Avatar
SPORTcoupe
I'm running about 9.5 Psi the rest of the run. I usually run the tires at 32 Psi for daily driving, but next time at the track I'll try ~18 Psi. I wish I could make it tomorrow but I have plans most of the day.
Interesting....SacramentoRaceway.com is down.
Looks like I have some confllicting answers on my wheelhop problem. Logically I would think that the rear should be soft and the front hard, so the weight transfers to the rear, but like I said, with that setting, I got some really bad hop. It might have been a coincidence but I can't risk doing something like that again, especially with my U-joint already giving me the warning clicks.
I'd really like to hear from people that have gone though all the trial and error and have come up with an answer.
~Alan
Old Feb 24, 2006 | 09:06 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
~Alan
Most people make that mistake. People want the rear to "squat". In actuality you want the rear to lift from the axle. This indicates that the real action goin on is increased downward force to the wheels. In essence the car is "planting" the tires in the rear.
Old Feb 24, 2006 | 09:32 AM
SPORTcoupe's Avatar
SPORTcoupe
Thank you! That makes perfect sense. With the proper pressure in the tire and stiff rear dampening, instead of the force being absorbed by the coilover, it will be used to push the tire down into the ground.
What is the reasoning for the soft front? I'm guessing it's so that the car doesn't do a 'bounce' when the weight comes back to the front. Am I right?
~Alan
Old Feb 25, 2006 | 08:43 PM
rscott's Avatar
rscott
you want it soft in the front not to dampen the front on the bounce but so you allow the front to lift more without having to also lift the weight of the wheels or deal with the ground friction. its the lift in the front that transfers the force to the rear. thats why i also said you can remove the front sway bar. it will allow more lift since the shocks will each be independent.
Old Feb 27, 2006 | 02:03 PM
SPORTcoupe's Avatar
SPORTcoupe
Gotcha. Cool. Soft front, stiff rear. Will let you know how it goes next time out.
~Alan
Old Feb 27, 2006 | 06:13 PM
scoarer's Avatar
scoarer
i just bought some tein flex too, just to confirm,the ones for our sc's and supra's don't come with camber adjust. plates right? One more thing..how stiff do u like it in other words, what do u set yours at?
Old Feb 28, 2006 | 07:16 AM
Cmedrift's Avatar
Cmedrift
are you guys dragging or cornering wheel hop on the rears you need a lsd. fill your gas with 3/4 of a tank instead of half full the weight will help. suspensionwise raise ur car a little dont preload your springs soo much you need suspension travell if you have a rear strut tower brace tighten it. ive ran on a ae86 for 4 years wheel hop and understeer are almost always present in that car good luck
Old Feb 28, 2006 | 07:23 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Wrong school of thought. This is regarding drag racing.
Old Feb 28, 2006 | 10:53 AM
SPORTcoupe's Avatar
SPORTcoupe
Our Suspensions don't allow camber adjustement via the top plates so the answer is no. We get regular solid upper mounts.
Ummm....ewww.
8F/6R (counteclockwise from hardest setting) for daily driving. 16F/0R for drag.
~Alan
Old Feb 28, 2006 | 06:16 PM
DETUNED's Avatar
DETUNED
Our cars use a double wishbone suspension which don't allow camber flates. You can get the JIC upper control arms to adjust camber.
Old Mar 1, 2006 | 07:13 AM
scoarer's Avatar
scoarer
thanks guys, i just put them in last night and im loving them..the only thing is that even on the stiffest setting i can still push the front and rear end down. But then i tested them out at an empty parking lot and i don't feel any body-roll at all and it makes controling the car sideways alot easier. Will ajusting the spring preload make it any stiffer?
