Dash Light Warning
Old Feb 14, 2006 | 04:38 PM
Radical350's Avatar
Radical350
Angry Dash Light Warning
"VSC" and "VSC Off" lights on instrument panel, both come on and stay on after 2 feet of forward motion. They just came on while driving home from work. Going to the dealer for inspection. Has anyone else had this combonation of warning lights come on?
Old Feb 14, 2006 | 04:50 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
if you are interested in pulling the code with a piece of wire, let me know. I will post instructions.
But...sounds like a wheel sensor.
Lee
Old Feb 14, 2006 | 05:10 PM
Radical350's Avatar
Radical350
Yea, I also think it is a speed sensor. I think everyone would be interested in the method of revealing the diagnostic test codes. If you have time for a brief rundown of the procedure.
Old Feb 15, 2006 | 06:29 AM
tonydt1g3r's Avatar
tonydt1g3r
Lee
you can pull the code without an OBD II scanner?
Old Feb 15, 2006 | 06:52 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Lexus specific codes cannot be pulled with a OBDII scanner. Must use a Lexus scan tool or a piece of wire to retrieve/reset those codes.
I will post something up on it
Lee
Old Feb 15, 2006 | 09:54 PM
Radical350's Avatar
Radical350
OK, my service agent "Fransico" at Lexus of Orlando (which I have used for 4 years) is A #1 in my book. All he said was "was somebody messing with the ODBII connector?"
I said No. I lied. I had been testing an ODBII Mongoose USB Connector and using my laptop and PCMScan software. To get some reads from the ECU and sensors. I must have screwed something up. He did not charge me! But he said in the future he would have to charge for labor. He said nothing about the SRT Intake. I am returning the Mongoose USB Connector.
You are right no DTC Error Codes could be read. I may have caused the error. Retrieve/Reset procedure will be very helpful for future. Thanks in advance!!!!
DTC: C1336 Zero Point Calibration Of Deceleration Sensor Undone.
Old Feb 15, 2006 | 09:59 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
What was the issue?
Lee
Old Feb 15, 2006 | 10:19 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Well it appears that they did not charge you.
A few things can set off that error code which is pretty easy to reset. This is the zero point of the Yaw sensor (dec in built in it) I spoke of in another post. I will get around to posting on how to reset those codes shortly. Thanks for sharing.
Old Feb 4, 2008 | 07:13 PM
dazpdx's Avatar
dazpdx
I've had this same problem for some time now... would LOVE the procedure to reset the yaw sensor, if you can spare a few minutes. I found about a dozen topics on CL about this exact same thing but none have a solution.
Old Feb 8, 2008 | 10:43 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Holy cow, guess I am a couple of years late on posting a how to on resetting the yaw.
OK, placed on my calendar to complete shortly.
Sorry for the delay.
Old Feb 8, 2008 | 10:44 AM
dazpdx's Avatar
dazpdx
That's funny, I was just wondering this morning if you had disappeared or not. Whew!
Old Feb 13, 2008 | 04:16 PM
dazpdx's Avatar
dazpdx
Took the car to Lexus. The tech plugged in the diagnostic computer, ran test mode on the VSC system and reset the yaw sensor. Fixed in five minutes.
kmalone67
Jul 15, 2018 06:43 PM
Local500
28
Dec 25, 2016 11:20 PM
mmman1963
Maintenance
Jan 28, 2013 07:00 AM
kramo
May 19, 2006 03:01 PM
