How many miles will the RX300 go with the original timing belt?
My 2000 RX has 124,000 miles and I haven't changed the timing belt yet. It's running great. Anyone know how many miles it can go before it actually breaks? I'm wondering if I could make it to 150,000 and then change it. Thanks all!
Super Moderator
I have heard from many 150,000 miles is the max you would want to go, though generally at 90K advisable to change that and the water pump since it is easier to get to durin belt chaning operations.
I replaced my RX300's timing belt at almost 90K miles. The major damage that could occur with a broken belt isn't worth the risk. I also had my water pump replaced at the same time. The cost of the water pump is very small once the mechanics can get to it.
Timing belt.
If your timimg belt breaks on your RX it will cause NO other damage. But, you will have to get it towed. The RX engine is a NON INTERFERENCE type engine and will Not distruct when the belt breaks. You will just lose your mobility.
For a listing of interference/noninterference engines go to the following.
www.ourautoshop.com
Click on OUR SERVICES
Scroll down part way and click on TIMING BELT CHART
Engines listed without an * are noninterference.
Hope this gives you peace of mind.
www.ourautoshop.com
http://www.gates.com/downloads/downl...older=brochure
The link also gives a good basic description of the differences between interference and non-interference engine designs.
I'd wouldn't take it past 150K. It's lasted long enough and I'd change it now rather than be sorry later.
Originally Posted by Scott1258
So which is it - interference or non interference?
Gates web site used to list RX300 as non-interfering engine. I would not trust it 100% since Gates lists ES300 as non-interfering but Camry V6, Solara, RX as interfering even though Toytoa uses 1mzfe engine for all of them.
Also timing belts worn out by age and temperature extremes more than by mileage, car makers list mileage because it is easy to do so. 90K is not the average, more like 99% confidence interval that RX will have a WORKING timing belt at 90K. If you don't believe me, as a Toyota technician whether he has seen a broken timing belt at 90K or do a search on Club Lexus and see if you can find one case of broken timing belts prior to 90K.
Originally Posted by mikey00
I just got an e-mail from Gates confirming their error in the new timing belt replacement guide.
It is definetly non-interference.
