EXCLUSIVE LS460 specs
Here's the original article (could be restricted to paid members only):
http://www.autonet.com.tw/cgi-bin/ne...i?qry=a5060200
Now, my summary of the report:
LS460:
Development code name: 070X
Production code name: 250L
Length: 5,100mm (vs. 5,025mm of LS430)
Width: 1,850mm (vs. 1,830mm of LS430)
Height: 1,480mm (vs. 1,490mm/1,470mm (air suspension) of LS430)
Wheelbase: 2,980mm (vs. 2,925mm of LS430)
Engine: 4UZ-FSE 4.6L V-8 (vs......well we all know)
Horsepower: 350hp @ 6,000rpm (vs. 290hp @ 5,600rpm)
Torque: 48.0kgm @ 3,300rpm (vs. 42.5kgm of LS430)
Transmission: 8-speed automatic (
)Fuel efficiency average: 9.5km/l (=22.35mpg, vs. 18/25mpg of LS430)
You heard these here first.
The original text for those who read Chinese:
AUTONET記者:蔡至兼
雖然距離LEXUS LS系列大改款還有一年多的時間,但日本方面卻為了導入該品牌,已經針對新車型作測試,就連車身尺寸與動力規格都有明確的資料,當然AutoNet又以最快速度取得相關訊息。
開發代號070X的LEXUS新LS,進入量產階段後代號更改為250L,雖然離正式推出還有一年時間,但基本上外觀造型與動力設定都差不多定案,就尺寸來說整體較現行款來得大,長度將近5100mm,車身寬度也增加近20mm為1850mm,車身高度則是1480mm,為了營造更寬敞舒適的空間,軸距增加了40mm為2970mm,幾乎快到達3公尺。由這些數字來看,新一代LS的車室空間絕對大到嚇人。
在動力方面,已經確定採用代號4UZ-FSE V8引擎,由於排氣量增至4.6升,所以新車型將不再稱為LS430,而是LS460。據了解這具4.6升V8引擎為直噴設計,功率輸出最大馬力將突破 300hp,為350hp/6000rpm,扭力值更逼近50kgm達到48.0kgm/3300rpm,縱使車身重量增加,引擎排氣量提升,但油耗成績卻相當優異,平均每公升可行駛9.5公里。
此外,LS460還有一項最大武器,就是採用密齒比的八速自排變速系統,這也較M.BENZ的七速自排來得更為精密,對於性能和經濟效益有正面影響。
350 hp sounds about right , max. torque will be about 362 lb-ft., both within expected range IMO. That's the first time I' ve heard of a 8 speed transmission from Lexus though . . .
Is the length given for the regular wheel base version BTW ?
8 speeds auto means: 6 speeds in forward+1 in Nuetral+ 1 in reverse= 8...
Actually, it did say in Chinese in the last paragraph that the 8 speed auto is a major weapon & is superior to the 7 speed of the Benz's tho . . .
anyway, the hp pand tq numbers are right, the 460 with around 350hp and the future 500 will have about 400hp
and i love it getting bigger
