I need some very very basic photoshop help - cutting out white space
I have a number of images for my audio diagram that I want to cut the white space out of, leaving only the objects in the images.
This is my draft image from a few days ago, and you can see the boxes around the items like the sub, the speakers, the battery, etc.
I've tried the lasso tool, then magic wand to cut the image, but I can only grab the outer sections.
Can somebody give me a quick step by step? I tried looking at some of the tutorials linked and the closest thing I could find was 'lowering a car' which didn't work for me, lol.
I've attached the sub pic I'm using below. Thanks in advance.
When you bring this GIF into your PSD of the whole car, the transparency is retained. I hope this made sense.
Basically just need to create a 'floating' object image.
https://www.clublexus.com/gallery/da...4610w7_big.gif
And you can see your new W7 located in your rear passenger seat.
And now I've got two subs!!
Then I just DL your car pic, loaded it into PS, and then added the GIF on top of it as another layer.
Just for the heck of it and to make sure it worked, I decided you needed 3 subs, this time in Visio (and saved result as jpg). (Wouldn't it be nice if it was that easy to add equiment?
Maybe I'm not getting it... can't seem to make it work.
I select the battery (for example) with the magic wand.. seems to go around it (or maybe it's selecting the white space?)...
and I don't seem to have a darken mode in Photoshop C5? Under Image, Mode it's not listed.
Edit - see your comments about darken mode above - ignore prior.
Now however through my trial (and all errors) I don't even get prompted for transparency option when I save as GIF.
Are you doing something to create a new layer when you select?
Like I said earlier, it only gives so so result.
I'm waiting for a real PS expert to chime in as everything I've learned in PS has been through experimentation and may not be the best way to do any of this.
Edit:
Thanks for all the help Neo!
Also - the easier way with the wand is to select the white space, then 'select inverse'
The steps (so I can come back tomorrow and remember them in my own words, lol).
- Using the magic wand tool, select the whitespace areas (use shift-click if there are multiple)
- Choose Select Inverse
- Select Layer, New, Layer via Copy
- Pick the new "layer 1" from the layers window
- Adjust image of layer if needed (darken, etc)
- Right click on Layer 1,choose duplicate layer and change 'destination' to 'new'
- Once the new image is created sans background, save it as a GIF with transparency turned on
I'm sure there is a shorter way to do this, but it works. Updates in progress below
Thanks again for all the help Neo!
