1st Test Snow driving with VDIM vs. AWD VSC
Old Feb 24, 2005 | 05:19 PM
Rockville's Avatar
Rockville
Default 1st Test Snow driving with VDIM vs. AWD VSC
It started snowing here in DC early this morning but really didn't start to stick until this evening. I thought this would be an opportunity to test out The AWD GS300 and the GS430 with VDIM and see how they fared. We have about 5 inches on the ground now and the streets are slick. Here goes....
I pushed the start button on our Matador Red AWD with Mark Lev. etc. Our back lot which slopes away was mostly empty except for a few service cars. I drove the GS300 slowly in circles until I felt where the traction started to break. The 17" all season run flats had good pull up the hill when going straight. It was very responsive to the throttle. When I took a u turn the rear would swing out like a RWD car. At low speeds the VSC didn't really kick in. After getting a feel for it I drove out on the road and as long as I didn't make a sudden throttle change or hard turn it was very stable. It had a little oversteer drift but it was totally manageable. When I got on it and took a turn the VSC would kick in to bring me back in line but in a fairly wide arc. I was trying to test the limits which a normal driver might not do in the snow....
I dusted the snow off our Black GS430 with 18" runflat all seasons. We have these orange foam squeegee things on broom handles that are made for removing snow. I took it to the back lot and tried the same circles that I had just made tracks with the AWD. I found that I actually had much more control in the turns than the AWD! It would automatically slow me down so I coudn't over accelerate. I tried a few straight up the hill runs. It proceeded slowly up the hill with no wheelspin. I had it floored but it wouldn't listen to my bad advice. Then I took it out on the street. It stayed under control when I pulled out and I forgot for a second that I was in the RWD. I accelerated up the Rockville Pike and the only thing I noticed was the VDIM amber light blinking. I felt the slightest waiver but that was it. I was cruising on the crust with abandon. VDIM is the bomb! I could get used to this and I'm glad my GS owners will not get into trouble with the steering in the snow. The car was unshakable and if I took a turn a little too fast it just started chiming and corrected itself. The arc was smaller and straighter. The only thing it couldn't do as well as the AWD was going straight up hill. The AWD had faster acceleration for this reason. Now if I only had a set of studded tires I think I could take the AWD on. I am definitely a believer now... In VDIM we trust.
Old Feb 24, 2005 | 05:32 PM
Car Freak's Avatar
Car Freak
THAT'S GOOD NEWS, THANKS
Old Feb 24, 2005 | 05:41 PM
LexFather
Guest
Posts: n/a
Wow that is a great review and surely of interest to those in snow having areas.
Old Feb 24, 2005 | 05:51 PM
Car Freak's Avatar
Car Freak
Question
It's funny, I live in Philadelphia and it snows here, I wouldn't say too much, but a lot during the winter. I always hear that FWD cars are so much safer in snow than RWD cars and I understand the reasoning behind it, but there are tons of RWD cars on the road here while it's snowing, so they can't be THAT BAD, right!?!
Old Feb 24, 2005 | 05:58 PM
Erick G's Avatar
Erick G
thanks for the AWD testing!
Im not far from rockville 40 minutes or so and yes the snow was fun today
Im glad the gs430 performed so well.. I was thinking of awd 300 BUT now
thanks to rockville, he might of sold me on the 430 and since I will buy from him
when time comes.. We will both be happy
Old Feb 24, 2005 | 06:02 PM
yaro1's Avatar
yaro1
Default Your conclusion:
Hmmmm.
So you conclude:
1) VDIM is more controlable than AWD w/ VSC in average driving in slippery and adverse conditions.
2) VDIM vs. VSC was more of a factor in control than AWD vs. RWD
3) AWD w/ VSC was better at climbing in snowy condition
4) VDIM is better than AWD in the snow overall
Do these sound in line with what you found? If not, correct me.
In NJ, stuff like that is the difference between getting home alive and getting well-acquainted with the interior overnight in some remote parking lot (maybe a little overexaggerated )
Thanks and Nice post!
Old Feb 24, 2005 | 07:05 PM
Threxx's Avatar
Threxx
By nature VDIM should be better in all handing and braking aspects regardless of AWD or RWD. Think about it... AWD vs RWD only comes into play when there is throttle involved. With steering and braking you still have 4 tires, 2 wheel steering, and 4-wheel braking regardless. Except with VDIM you have a better management system.
Now with accelerating I'm pretty the AWD should win regardless... even with the smartest computer management system in the world in a RWD car. 4 wheel drive is hard to be taken down by 2WD unless the 4WD has no traction control at all and a dumb driver behind the wheel.
Old Feb 24, 2005 | 07:38 PM
Rockville's Avatar
Rockville
Default More testing needed....
After I made that post I took an '05 GX470 out on the lot to see how it took the turns as it has a 40%/60% rear wheel power bias and it was very similar to the GS300 AWD. The GS 300 AWD has a 30%/70% rear wheel devotion of power. I will predict that the new RX400h with VDIM will do much better in the snow than the RX330 with VSC. VDIM takes over during extreme situations. On the GS430 no matter how poorly I steered and stomped on the gas it never got flustered or lost control. I can imagine some of my more challenged customers being saved by the VDIM. The AWD GS got much more traction and acceleration coming out of the hole so that is why I believe it would win a wager in say an eighth of a mile straight line. When taking turns the VDIM will do whatever is needed to maintain overall stability and will cut speed as a precaution. The AWD will let you take it a little farther before it decides enough is enough and intervenes. I didn't attempt any left foot braking techniques as I am quite rusty at them. With a little practice the AWD would make a fun rally car. I try to visit Bend, Oregon each year to go skiing with my friend Tom Hamilton. He is a ski instructor and ex rally driver and the drive up to Mt. Bachelor with him in his Audi 5000 Quattro is almost as fun as the skiing. Last year unfortunately after having some work done at the local Audi dealer it caught fire in front of his house! I would like Tom to drive the GS300 AWD up the mountain with snow specific tires like he had on his Audi. Coming down the hill one day a snowmobile launched from the side of the road from a drift and hit a van full of skiers after a day on the slopes. You have to be ready for anything in the wilderness. Most AWD SUV's and cars have a tendency to understeer which is when you are headed straight at something while your wheel is turned. The SUV's will flip easily if they get back on dry pavement and very suddenly veer. The GS300 AWD feels more like a RWD car to me. The AWD definitely can take you up the steeps and the VDIM can keep you in check in the curves. These are both a lot of fun to take out in the Tundra. BTW on the way home a RWD pick up truck started swinging wildly back and forth in front of me and then headed over to the guardrail and slid along it until it came back on the road again and he just kept on driving! He's going to have some paintwork to do on that passenger side... Do I attract this stuff or what? Now if he'd had VDIM.......
Old Feb 24, 2005 | 07:54 PM
JHStrange's Avatar
JHStrange
great comparisons and a help to all of us. I'd guess you've got more snow in MD then in Bend this year. My wife was up at Timberline on Mt. Hood today and 45deg., not much snow there.
Old Feb 27, 2005 | 04:00 PM
looknow12's Avatar
looknow12
Rockville,
On the GS430 w/VDIM, do you notice any difference in the abruptness of the traction control cutting power? My 2000 GS400 (even my GX470 will do this, not as bad though) would abruptly cut power when traction was lost making it very slow to accelerate. I wondered if the VDIM computer helps the traction control system as well.
In my mind, there's no reason power cannot be dynamically reduced to the slipping rear wheel and then again quickly released when traction has returned. We need faster responses from the traction control CU.
Last edited by looknow12; Feb 28, 2005 at 05:05 AM. Reason: GS430 reference should be GS400
Old Feb 27, 2005 | 10:54 PM
Itsuki_23's Avatar
Itsuki_23
Any of you guys use snow tires? For example Bridgestone Blizzak WS-50. There is huge diffrence in grip compared to all-season tires, even with AWD.
Old Feb 28, 2005 | 10:03 AM
TRDFantasy's Avatar
TRDFantasy
Very interesting ... looks like the GS430 is not in desperate need of AWD after all. I guess the only complaint about VDIM is that it stops you from pushing the car to it's limits ... and it can't be turned off, as far as I know. But of course, you can always get the GS300 AWD for more fun driving . I guess the ability to turn off VDIM would be icing on the cake .
VDIM totally makes sense ... Lexus is not trying to follow the Germans ... Lexus is going along it's own path ... and setting it's own standards. Toyota wants Lexus cars to minimize all the bad and dangerous aspects of driving while maximizing everything else. VDIM has gotten Toyota one step closer to that ideal. No doubt VDIM is a very advanced system that's safer than any German system, including Quattro, or Mercedes VSC.
Old Feb 28, 2005 | 10:23 AM
Car Freak's Avatar
Car Freak
Question Too much sophistication
With all this sophisticated technology how would someone know if something isn't working correctly? Now I'm not talking about the radio, that would be obvious that it wasn't working. But say a part of the VDIM, how would you really know if something was wrong or not working correctly, would you have to wait until you get into an accident? Anyone ever think that cars are becoming too advanced? I don't know maybe this doesn't make sense.
Old Feb 28, 2005 | 10:51 AM
JHStrange's Avatar
JHStrange
Good point on knowing if something's wrong. I always say I can't be too paranoid. Of course if I really worry it should probably be about that tire to road patch; 6-10 square inches of contact just looking to lose it on a bit of sand or oil on the road. Exciting
I get more concerned about what happens to all that electronics 10 years from now.
Old Feb 28, 2005 | 11:00 AM
XeroK00L's Avatar
XeroK00L
Actually, quite the contrary. VDIM is intended to allow you to push the car to its limits at all times, limit being the boundary in which the car can perform without losing stability though.
Your complaint should be that the VDIM stops you from pushing the car beyond its limits.
