Help 18" IS250 rims on 1994 es300
I came across A really Good deal on some 18" IS250
Front Wheel Size: 18" x 8" 45mm offset Rear Wheel Size: 18" x 8.5" 50mm offset Bolt Pattern: 5x114.3 The question is will the rear rims fit or what can i do to make them fit? http://images.craigslist.org/5Na5L95...588a6f15c4.jpg |
It would probably would be tough to fit a tire on that 8.5" wide wheel in the rear and have zero rubbing issues. The wheels would bolt up fine but there would be clearance issues in the rear because of the aggressive width and the offset is a little on the high side. Not an ideal fitment, may take some work.
