alignment needed for new wheels?
Old Feb 6, 2002 | 09:36 AM
lex430's Avatar
lex430
Default alignment needed for new wheels?
I am just wondering, I am about to get my new 18' wheels (currently on stock 16'), and I am curious if I need an alignment after installing the new wheels?
I had one done when I got my L-tuned spring/shock installed at the dealer, this was few months back,
opinions?
Old Feb 6, 2002 | 10:13 AM
///MDex's Avatar
///MDex
Default Re: alignment needed for new wheels?
Originally posted by lex430
I am just wondering, I am about to get my new wheels, 18's, and I am curious if I need an alignment for it?
I'm not an alignment expert, but my logic would tell me yes.
You car will not ride the same way, and will be a different height and weight more than likely, so a re-alignment, at least to me, would make perfect sense.
Keep us posted.
Old Feb 6, 2002 | 12:19 PM
lex430's Avatar
lex430
any special settings? I know it's been discussed in length, but haven't seen any "correct/proper" settings with 18' wheels and specific suspensions.
Should I go to the dealer for this? or any wheels shop can do, big O, costco..etc?
Old Feb 6, 2002 | 12:28 PM
///MDex's Avatar
///MDex
Hmmm - I don't know about 18s, but you can see factory specs here.
https://www.clublexus.com/forums/sho...threadid=31735
They are not dead on numbers really; more like a range, but a higher end shop with a Hunter machine should do you well.
Heck, I found out last week that a local dealer has a Hunter machine on-site, though I bet most dealers would frown on trying to balance and align anything other than factory wheels.
Worth a call.
Old Feb 6, 2002 | 12:44 PM
JacobT
Guest
Posts: n/a
No. You don't need the alignment. Alignment is only needed when suspension geometry was changed. By just changing the wheels, if the total diameters are within 1/2" difference. Don't worry about the alignment.
Old Feb 6, 2002 | 12:51 PM
///MDex's Avatar
///MDex
OK - answer me this:
Say I went form 17s to 19s - would I need an alignment then?
Wouldn't the larger wheels add weight to the car and / or suspension components, thus changing the alignment values?
TIA
Old Feb 6, 2002 | 02:17 PM
JacobT
Guest
Posts: n/a
Alignment is basically adjust the angle the tire touches the ground(camber) and the parallelism of the wheel pairs(toe). Caster is fixed for GS. If your rim is perfectly streight, you should be able to remove the wheel and get an alignment job done. The alignment job is to correct the wheel mounting surface relative to the suspension, it has nothing to do with the weight nor the size of the wheel.
I always like to put my 16" stock wheels on for an alignment job then put my 18" rims back on myself to avoid any scratchs on my C5's.
mexguy89
Mar 18, 2013 07:29 AM
Blue98Gs3
Suspension and Brakes
Dec 29, 2003 09:33 AM
bluelex
Jul 12, 2003 06:51 PM
EastCoastES
Nov 17, 2002 01:24 AM
BatKing
Sep 19, 2002 01:47 PM
