Offset 40 front 23 rear,...
front-19x9-40 offset/ rear-19x10-23 offset. Will this fit a GS400?
The front should fit just fine, the rear will most likely need a stretched tire set-up and rolled fenders. IMO, those offsets are not ideally matched, the front is somewhat conservative while the rear is quite aggressive. Just my 2 cents :)
Originally Posted by Rare1
(Post 2984656)
If they're negative 40 and negative 23 then it's definitely not going to work. |
lol i also hope they are positive offsets. if they are negative? man, that's like truck wheels :D
yeah, i don't think they fit well on the car, front and rear not proportion |
front will work no problem, rear needs to be a much higher offset somewhere around a 38 to 45 depending on rear tire size might have to roll the fender a little,
check out www.sizeitup.com for more tire & wheel plus sizing and fitment data |
Ok the guy doesn't know if the offset is positive or negative, If it helps they were on a M3.
(Post 3001074)
Well,.. that does it. I can't buy them. I totally forgot to check the bolt pattern. Thanks Seize.
