GS w/ 20x11 rear? will it fit?
I asked this question and got no response in the Makaveli rim thread is this doable?
thanks - Erick |
I think Bob 'SoCalSC4' was talking about doing that with his GS...not sure but I think I read it somewhere in this forum awhile back. Bob where you at, maybe you can weigh in on this? :)
-Seize |
Re: ...
Originally posted by Seize I think Bob 'SoCalSC4' was talking about doing that with his GS...not sure but I think I read it somewhere in this forum awhile back. Bob where you at, maybe you can weigh in on this? :) -Seize -Anthony |
yes it's very doable. 20x11 is what bob is doing to do. you don't need major fender mod. i bet shaving it would be all you need at the most
They won't fit without a little work.
Hey there...
I shaved & rolled the rear fenders mainly to accommodate the aggressive offset of my current 20x10 +36 wheels with 285/30-20 tires. I like the "aggressive" european look, and was willing to go the extra mile to make it work... The short answer is yes, an 11" wide wheel will work on a GS, including the first-gen cars- with the correct offset. Based on my current wheel, I could actually go to a 20x11.5" and still have about 3mm clearance to the coilovers. In February, I will get the first set of Pirelli's new NERO 255/30-20 and 305/25-20 tires. These intrigue me because they are closer to the factory tire diameter (and the rears are WIDE!): my current 20x9" are perfect for a 255, but the 305 rear tire really likes to be on an 11" wide wheel. To achieve this, I will simply change the inner rim of my three-piece wheels to add the extra inch. The wheels won't look any different relative the the fender- the additional width goes to the inside. Depending on which wheel you choose, an 11" wide wheel may or may not be available in an offset which is appropriate for your Lexus. The wheel manufacturer should be able to recommend widths and offsets for the GS. If they can't figure out how to make the 11" wide wheel work, I would look elsewhere... Forgive me if I don't just come out and tell you what offset you need, but I spend a ton of time figuring this stuff out for HRE- part of what makes our wheels so special is how they fit on cars. Would the Colonel give away the recipie for his "eleven herbs and spices?" (guess not... now that he has gone to the big bucket of chicken in the sky!) :D |
awesome reply bob, as usual :) can't wait ti see pics of the 11" wheel from behind ;)
You just gotta do a post of that look!
DT |
1 Attachment(s)
great post socal!! so this more than likely will fit with the right offsset....
also what do you think of these wheels? Makaveli wheels |
I have to ask this, how much lip action is TOO much?? I have seen 3.5" lips and others around that much, I wonder if 5" may be a little too much? Dont want to start that reverse offset trend again!! LOL
I'm just asking to see what you all think about this! |
Originally posted by SoCalSC4 Hey there... I shaved & rolled the rear fenders mainly to accommodate the aggressive offset of my current 20x10 +36 wheels with 285/30-20 tires. I like the "aggressive" european look, and was willing to go the extra mile to make it work... The short answer is yes, an 11" wide wheel will work on a GS, including the first-gen cars- with the correct offset. Based on my current wheel, I could actually go to a 20x11.5" and still have about 3mm clearance to the coilovers. In February, I will get the first set of Pirelli's new NERO 255/30-20 and 305/25-20 tires. These intrigue me because they are closer to the factory tire diameter (and the rears are WIDE!): my current 20x9" are perfect for a 255, but the 305 rear tire really likes to be on an 11" wide wheel. To achieve this, I will simply change the inner rim of my three-piece wheels to add the extra inch. The wheels won't look any different relative the the fender- the additional width goes to the inside. Depending on which wheel you choose, an 11" wide wheel may or may not be available in an offset which is appropriate for your Lexus. The wheel manufacturer should be able to recommend widths and offsets for the GS. If they can't figure out how to make the 11" wide wheel work, I would look elsewhere... Forgive me if I don't just come out and tell you what offset you need, but I spend a ton of time figuring this stuff out for HRE- part of what makes our wheels so special is how they fit on cars. Would the Colonel give away the recipie for his "eleven herbs and spices?" (guess not... now that he has gone to the big bucket of chicken in the sky!) :D Keep me posted ;) |
Originally posted by DGOT20s I have to ask this, how much lip action is TOO much?? I have seen 3.5" lips and others around that much, I wonder if 5" may be a little too much? Dont want to start that reverse offset trend again!! LOL I'm just asking to see what you all think about this! |
Originally posted by rominl i was like man... where's the wheel. i literally had to FIND it |
