TX Models (2024-present)
Mileage on original tires
Old May 28, 2026 | 11:08 AM
Patriotic1's Avatar
Patriotic1
9th Gear
Default Mileage on original tires
I'm at 22K miles on my 2024 500h, and I just noticed this morning that my remaining tread life appears lower than I expected. I rotate the tires every 6 months. It looks like the outside edges are wearing slightly faster than the middle if that makes sense. I guess I just thought I wouldn't have to worry about getting new tires before 30K miles, but it appears as though I may need to before winter. What sort of mileage are others seeing from the OE tires?
Old May 28, 2026 | 08:51 PM
johnpinnc's Avatar
johnpinnc
I'm just over 25,000 miles on my 2024 TX 350. I just had the car in to the dealer for its 25,000 mile check, and there was no mention of need for tires at this point.
Old Yesterday | 03:53 AM
DonsCA's Avatar
DonsCA
That is usually underinflation or bad alignment.
Old Yesterday | 04:39 AM
lesh's Avatar
lesh
4th Gear
Outter wear on tires typically indicates under inflation. Be sure to check your tire pressure regularly, especially if you live in a colder climate. Cold temperatures can rapidly reduce the pressure inside tires. I live in South Florida and we had a 3 week cold snap in January, 3 consecutive weeks of overnight lows in the 30s. My tires lost between 8 and 10 lbs of pressure each. Be sure they are inflated to the levels recommended on the door jamb sticker.
Old Yesterday | 07:16 AM
SilverElegance's Avatar
SilverElegance
correct tire pressure checked every month helps get even wear if car aligned properly....
MrRick
May 6, 2021 01:02 PM
saifm73
Jun 28, 2020 09:12 AM
GOT8SPD
RC F (2015-present)
May 12, 2018 10:20 AM
webeinky
41
Nov 28, 2016 06:17 PM
Seadee456
Sep 16, 2007 06:05 PM
