TX Models (2024-present)
TX on 24's
Old May 8, 2024 | 04:42 PM
stunt66's Avatar
stunt66
Default TX on 24's
Got the 24's on the wifes TX a couple weeks ago and some members asked for pics. Wheels are Status Venti 24x10+35 offset and the tires are Lionheart LH10 in a 295/35/24. Stock side wall on the 22's are 4.52" and I went with the biggest tire I thought i could fit to maximize sidewall height and these work out to 4.09". I went the same with the 22" winters 275/45/22 and on both sets I had to assume all risk of them not fitting because the TX is too new and no rim dealers were able to confirm any non OE sizes. I only got a couple short drives in on the stock 22's before I swapped to winters but compared to my winters which are a 275/45/22 the ride has not suffered at all. It will ride a bit harder compared to the 22's but nothing noticeable, the TX suspension is set up nicely to handle the 22's and 24's. The fronts are flush to the fender and the rears needed a 5mm spacer to get them flush. There is some minor rubbing on the inside corner of the mudflap when the wheel is fully cranked reversing but nothing else thankfully I also added some Lexus wheel caps.
Old May 10, 2024 | 10:48 AM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
Looks good.
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old Jun 4, 2024 | 06:47 PM
mikedozz's Avatar
mikedozz
Looks great!! How's the road noise? 35 series tire has some good meat.
Old Jun 10, 2024 | 09:43 AM
stunt66's Avatar
stunt66
Thanks! Road noise is not an issue at all, even with the music on low there isnt anything noticeable. Going to a 35 was a bit worrisome but I went with the widest tire I could do maximize the side wall of the 35. The TX suspension is also amazing and handles these no problem.
TBelinski
Jul 5, 2023 10:33 AM
ChristianM
12
Jul 1, 2013 07:10 AM
donsmith
Apr 3, 2012 04:53 PM
SickES350
28
May 1, 2010 03:48 PM
