The wheels are 18" in diameter by 9" wide. They are 5 lug pattern with bolt circle of 114.3mm (or 4.5"). These wheels have 10 holes but both sets of holes are the same bolt pattern. The have a postive offset of 44mm (+44 offset)(6.25 backspace). Could those fit on 2001 Lexus GS430 without any kind of spacer and modification? Thank you.
+44 offset in the front for AV3 should also clear the big brake calipers. I have RH C5 which is streight spoke design with +44 offset. It almost clears the Supra TT caliper, with the curved spokes design on AV3, it should be no problem.
Originally posted by RacingAristo Does anyone know where they sells new tires cheaper than tirerack.com?
try America Tire Co. They match prices, even tirerack ones. Even if it's not cheaper, it's better to buy tires at a store (they offer free mount on all tire purchases) than online.
