Going to add spacers, need some advice about tires too fat or not....
Old 07-14-10, 11:21 AM
masboy
masboy's Avatar
Default Going to add spacers, need some advice about tires too fat or not....
my wheels setup : 19x8 +37 235/35 (front) and 19x9 +45 265/30 (rear)
going to add spacers 20mm front & 30mm rear.
I'm pretty sure I have to shave / roll fender, right ? and are my tires too fat ? no finger gap all around.
thanks in advance!
Old 07-15-10, 09:23 AM
masboy
masboy's Avatar
can anyone help me on this ?
Old 07-16-10, 08:27 AM
Infamous 1
Infamous 1's Avatar
I think you might actually be ok. But a roll(up front) and shave(in the rear) couldn't hurt.
Old 07-18-10, 09:35 PM
sleeper408
sleeper408's Avatar
I'm running 225/40/19 on my 19x8.5 +21 for the front, and 285/35/19 on 19x9.5 +23 for the rear. That means your 19x8 after spacers should be equivalent to 19x8.5 +24 which is very close to where mine sits. The tires you will use should be fine and probably won't taco your fender. My 225/40 is still slightly too tall and did some damage going up and down driveways. I would get them rolled prior to adding the spacers. Your rear wheels will be equivalent to 19x9.5 +22 after spacers which is also very close to where my wheel sits. You should definitely be good with 265/30 with just a slight shave. I fully shaved mine and 285/35 fits, just barely.
Old 07-22-10, 06:42 AM
masboy
masboy's Avatar
thanks guys! finally someone replied....lol
vboi4life
06-21-12 07:05 PM
gridlock13
02-22-12 05:26 PM
OscarThai
12-03-10 11:26 PM
Bigstdawg
05-09-08 10:11 PM
Quick Reply: Going to add spacers, need some advice about tires too fat or not....
