What brake fluid to use?
Old 02-07-08, 08:47 PM
jeff1941
jeff1941's Avatar
Default What brake fluid to use?
Es300 1997
what brake fluid is best for my car?
Im thinking of either Valvoline Brake Fluid: Dot 3 & 4; Synpower(R); 32 oz. or Prestone Brake Fluid: Dot 3; High Temp; 32 oz. from the locol auto store
Which type of fluid will damage the brake system?
Old 02-07-08, 08:58 PM
GSteg
GSteg's Avatar
Look on your cap. I believe yours is DOT 3, so any fluid that is DOT 3 approved. Or you can go with Toyota fluid. a bottle (about the same as the ones you get at autozone) is about $4. Similarly priced, but at least you might feel better about using Toyota
Old 02-08-08, 05:53 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
really, use whatever you want EXCEPT dot 5
3, 4 and 5.1 are all compatible with your system... really, unless you are racing, it's not gonna matter a whole lot, so long as it's clean, no moisture or air...
Old 02-08-08, 07:05 AM
LexFather
Guest
Posts: n/a
Yeah, all the brands mentioned are fine and none there really superior to the other for daily driving.
Old 02-08-08, 07:16 AM
Lexmex
Super Moderator
Lexmex's Avatar
ATE SuperBlue is my favorite, I have used that one you mentioned from Valvoline for a few years, also not too bad, but if you aren't going to be changing it out to often, ATE is quite nice.
Old 02-08-08, 10:16 AM
JesLet
JesLet's Avatar
Valvoline SuperSyn.
Old 02-13-08, 11:00 AM
Lexusfreak
Lexusfreak's Avatar
Thumbs up
Another for ATE Super Blue! AKA Smurf Blood. It's awesome stuff.
Old 02-27-08, 03:25 AM
radicalrev
radicalrev's Avatar
how much brake fluid do you need to replace??
Old 02-27-08, 08:26 AM
Lexmex
Super Moderator
Lexmex's Avatar
Usually about 1 liter.
Old 02-27-08, 12:17 PM
radicalrev
radicalrev's Avatar
thanks!! ATE super blue then...
Old 02-27-08, 05:17 PM
radicalrev
radicalrev's Avatar
one more question, so all DOT 4 brake fluids are compatible with DOT 3 required cars?? The 2IS brake fluid is DOT 3...and ATE super blue is DOT 4...so it doesn't matter that I use the ATE DOT 4 brake fluid right?? just want to clear things up...dun wanna have brake failure in the middle of the highway...haha
Old 02-27-08, 05:24 PM
jeff1941
jeff1941's Avatar
From what i was told dot 3 and dot 4 is the same except dot 4 has a higher boiling point so its better.
Old 02-27-08, 08:03 PM
GSteg
GSteg's Avatar
Check with your owner's manual to see if DOT 4 is okay. A lot of times, the chemistry difference between the DOT 3 and DOT 4 fluids are not compatible. They may differ and the rubber lines, seals, etc in your brake system may not do well with DOT 4. Sometimes manufacturer makes DOT 4 that are specified to be compatible cars where DOT 3 is required.
Old 02-27-08, 10:05 PM
mitsuguy
mitsuguy's Avatar
incorrect...
the only difference with DOT 4 is higher boiling points...
DOT 5 is the only of the above listed that is not compatible... it is a silicon based fluid, whereas the others are not... (they are glycol based, and composition depends upon manufacturer, not DOT rating)
they however, should not be mixed - there is a possibility of a chemical interaction, but highly unlikely...
Old 02-27-08, 10:11 PM
mitsuguy
mitsuguy's Avatar
here's an interesting read I just found: http://www.motorcycleproject.com/mot...rakefluid.html
Quick Reply: What brake fluid to use?
