Yokohama AVS sport tire pressure?
Wanted to know if the Yokohama AVS sports (18s) need a higher air pressure - I am at 37psi but my tires say max pressure at 51psi. I just looked at other 18 tires and they stated 35 max while my 18 (225 & 265) say 51? Should I fill up towards 50?
thanks
thanks
I had AVS sports on the stock 17's and ran around 42 PSI front and 40 PSI rear. On my 18's I run my S-03's about the same, which already results in a hard ride. The higher you go the harsher the ride -- and your handling does not necessarily improve as you are probably reducing the contact patch. Part of the fun is experimenting and letting the butt-ometer or other more "scientific" method tell you what's best.
HKGS300
Wheels, Tires & Brakes Forum
04-11-03 12:28 AM
