wheel fitment question
just picked up a 91 ls400 thats pretty much stock.
looking into getting megan coil overs and some staggered 19's
I found a set of used ssr d5r's in 19"x9" 37 offset and 19"x10.5" 50 offset and was wondering if they would fit with out to many issues.
thanks for the help
thanks for the help
Both are wider than recommended, the front offset is close to where you need to be. But the rear will probably need a spacer to push the wheel out. Again both are wide and will probably require a fender lip roll and/or reshaping the inner fender liners. You're about 1" wider than I would recommend front and rear.
