Why are my rear Michelin tires vibrating when car sitting for few hrs or more?
I have these 4 new Michelin Primacy MXM4 tires on my 2013 Lexus GS F-Sport and they were road forced to 8, 10, 14, and 15 lbs which is Left front, right front, left rear, and right rear respectively.
The tires are smooth when warmed up but there is vibration in the front seats when I am getting up to 70 mph and around that speed to 75 mph or so I feel it for at least 5 miles before its smooth with a small residual vibration felt in seat around 70-75 mph. Now, I checked pressure daily to make sure and I also know it cannot be flat spotting as this vibration returns again when the car sits for about 4 or so hours on the parking lot in the hot sun or in garage during nights even when its 80 plus degrees outside. I am not getting steering wheel vibration so its the rear tires.
I had to replace 1 of the rear tire when it was 25 lbs and now its at 15 lbs with replacement tire. Since its dynamically balanced well I am not sure if this Lexus is ultra-senstive to the road force of the tires???? Should the rear tires be rematched to get the whole assembly below 10 lbs to prevent this initial drive off vibration when car sits and rear tires cool down leading to a warped condition? No other cars that I have had ever does this with Michelin tires. I know that flat spot occurs at cold temperatures in winter with performance tires so this case is very ODD. '
Anyone from tirerack can chime in? I might need to get at least 1-2 more tires replaced under warranty policy.
Maintenance Moderator
Since it goes away, I would say vwynn is correct... Certain tires will exhibit it moreso than others... I've had the issue before and the higher performance tire you have, the more likely it is to happen... For example, a Michelin Pilot Sport will have more of a chance than say a Michelin Primacy... Some cars are more sensitive to it than others, I would definitely have the balance double checked to be on the safe side, but getting it less than 15 lbs of road force might be impossible without going through quite a few different tires and wheels...
If it is a heat issue and they only do it when cold, it is most likely because they used at least one layer of nylon belting in the tire. Nylon is a great thing to use in high performance applications because it shrinks, or tightens up as heat is added, but, to do this, it may be a sacrifice in that when it loosens up when it cools in one spot, it may cause a temporary flat spot... It always goes away when the tires get some heat in them though...
Thank you mitsuguy. The primacy are the top rated grand touring tires and it summertime with warm temps so i am surprise at this. Isnt the primacy with polyamide belt like my bmw with the pilot exaltos a/s tires? The exaltos are smooth no matter what. I will get tires road force again to see if we can get it match mounted to around 10 lbs.
You are right, It doesn't go away completely but is minimized as the tires get hotter. When its cooler the vibration is heavy at first and slowly diminish but present after 10-15 miles of driving around 70-75 mph zone. The rear left rim was hopping quite a bit and the right rear is slightly bent. No potholes and only 3 months old car. Lexus dealer has contacted regional representative to come and look at the wheels and will hopefully replaced the warped ones since its likely defect production or improper transportation of the car. I have insurance for the tire/wheel just in case.
I am getting the newer Bridgestone Turanza Serenity Plus tires this week and should be mounted and road force balanced this Wedneday morning at a tirerack installer.
I don't really think it has anything to do with sitting in a warehouse...
10-15 lbs is not necessarily high, in fact, that is very acceptable normally... I am still sticking with it being the way the high performance tire is designed - some tires just get "flat spots" when they sit that go away when they are warm...
Hopefully you will like the new Serenity's... The last ones were amazing... I get to go test them on a course in two weeks...
Anyways the Serenities are supposed to be nice and I look forward to them. Let me know how you like them soon.
Those numbers refer to how much variation in how round and how uneven the tire and wheel combination runs...
farmerchen
06-30-14 11:43 AM
