Will these fit okay on a 99 GS4?
Northern California Regional Officer
Bolt pattern:: 5x112
Offset:: .35mm
Fitments::Most Mercedes Benz, some Audi
This is from an eBay auction for a set of Dronell's that I have been searching for...
thank you.
Offset:: .35mm
thank you.
Will: On the second-gen GS, a 9" wide +35 is a bit aggressive- depending on the tire, it may stick out a "butthair" (this is a highly-technical HRE term) at the top of the front fender. It works fine on the rear, though. On a 9.0" I'd recommend a +37 to +42 on the front newer GS.
An 8.5" +35 works fine, however- it is a 1/4" (about 6.35mm) more inboard than a 9.0" +35.
That's a great question... to my understanding, the Supra and SC stuff interchange, but I'm not sure that the GS/SC stuff interchanges.
I'll drop Jomar @ TRD a line & see if he knows!
thanks a lot...
i know some of the GS and SC stuff are compatible...my thinking is that the early SC probably does not have the TT breaks, so stock GS break parts(same as NA supra) should work..
