Ignorant Center Cap question
I've got a newbie wheel question.
I've got an LS430 with 17's. I'm putting a set of 19" Moda's on this weekend. I'd really love to change the center caps out for Lexus ones. Are all center caps interchangeable? How would I find out what Lexus emblem caps would work?
Thanks so much...
- kent
Thanks so much...
- kent
Maintenance Moderator
Thanks so much...
- kent
Thanks so much...
- kent
Most all of the Lexus center caps are similar or the same in size, IIRC, so choosing a different one likely won't matter much...
Might have to do some sort of custom mod to the MODA center caps - might even be able to make it work somehow...
you may have two option one custom made to fit by measure the area of the factory one to the after market one and if they are within a couple of mm of each other you can shave the factory ones to fit
second you can obtain blank one from ebay and get some decal to fit over the blanks
OakTwnPnoy
SC- 1st Gen (1992-2000)
11-10-04 11:43 PM
