Winter Tires for IS 300 Sportcross
Old 04-22-09, 12:40 PM
sway162
sway162's Avatar
Question Winter Tires for IS 300 Sportcross
I recently purchased a 2005 Lexus IS 300 Sportcross, fully loaded except the navi. Has both the LSD and VSC. I live in Lakewood WA and this past winter was pretty bad with snow and ice. I am looking around for a good set of winter tires to swap them on when that time comes. I need some ideas on what to get and if I should go with all the same tire size at 225/50/17 or 225/50/16...I don't know, i' am clueless on this. Thanks for the help!
Oh and i forgot to mention that my current tire size is 215/45/17 front and rear 225/45/17..
Last edited by sway162; 04-22-09 at 12:45 PM. Reason: Forgot to add current tire size
Old 04-22-09, 09:07 PM
steviej
steviej's Avatar
For winter go with the same size on all corners.
I highly suggest the Michelin Pilot Alpin PA3 if it comes in your size. Best thing I bought for my GS this past winter and we got lots of snow. Great on dry cold pavement too.
steviej
Old 04-23-09, 07:26 AM
sway162
sway162's Avatar
steviej
Thanks Steviej for the input. I will look into those.....I wonder if it will make a big difference if I just got a really good set of all season as opposed to winter tires. Then again, my wheels are rear-wheel drive.....
Cheers
Old 04-26-09, 01:21 PM
steviej
steviej's Avatar
If you were AWD I would say probably.
Since you are RWD I would say go with the performance winter tires and be safe all round.
steviej
mikemu30
ES - 7th Gen (2019-present)
12-14-18 02:16 PM
sil-300
12-13-09 03:50 AM
bad co
11-17-09 07:12 PM
cdnguy
09-29-05 09:37 AM
ES3
08-12-05 09:14 AM
Quick Reply: Winter Tires for IS 300 Sportcross
