225/40 vs 235/35
225/40 vs 235/35
Is there a difference between 225/40 vs 235/35?
I am looking to get tires for my wheels. I will be running 18x8 fr. 18x9 rr. I am trying to get that equal look from the front and rear tires. Either it be stretch or square. I am just looking for advice.
My options would be:
fr.
205/40
215/40
215/35
rr.
225/40
235/40
235/35(rare and expensive!!)
Thanks in advanced
fr.
205/40
215/40
215/35
rr.
225/40
235/40
Thanks in advanced
Maintenance Moderator
http://www.discounttire.com/dtcs/infoTireMath.dos
225/40-18 and 245/35-18 would be the closest... 235/35-18 would be quite a bit shorter
is this for an IS300? I'd run 235/40-18 and 245/40-18 or if you wanted wider in the back, 265/35-18 would be the same diameter as 235/40...
A tire has a steel belted tread ply - this steel belt can neither expand nor contract with regards to the wheel width... I used to know guys putting 315's on 8" wide wheels and still the same diameter... the reverse also applies - a narrow tire on a wide wheel still has the same diameter / circumference...
they may appear different, but I guarantee its the same...
ShiftyD2k
Wheels and Tires Classifieds
05-25-12 10:54 PM
